I need instructions for installing for Camber Kit and Rear LCA & Sway Bar
I just bought for a 98 civic coupe, Blox front camber kit, rear sway bar, adjustable endlinks and LCA .. I want to install this myself in my garage.. does anyone know the steps to doing this or any threads, websites, instructions thx!
copied..
copied..
Re: (ShrimpCrab)
if it is the upper control arms (for the camber) then:
remove axle nut
jack her up
remove shock fork (fork on bottom of shock)
remove lower and upper ball joint (will need special tool(ball joint puller))
take off steering knuckle
under the hood there is two bolts on the shock tower that remove the upper control arm remove those and the upper arm shuould pull out with a little persuason(sp?) replace with the new one and you are good to go!
as for the sway bar and rear lower ill be able to help you as soon as i do mine!
remove axle nut
jack her up
Re: (madmanmaigret)
why did you tell him to take the axle nut off? that is not necessary at all. As far as the rear lcas just look at them and it should be straight forward. I am gonna warn you now your bolts holding the lcas might be frozen. Then for the rear sway bar and tie bar it mounts to the subframe then bolts up to the lcas. Rear camber kit would be installed right above your rear brake when you look you should be able yo figure out where it goes. Pretty straight forward stuff here dude.
Re: (ReFreSh)
ok got the camber kit down.. now the rear ..
so take off the
LCA FIRST
then the
Rear Sway and Endlinks
put back the NEW LCA
then
Put back the New Rear Sway and Endlinks
Correct??
so take off the
LCA FIRST
then the
then
Correct??
the_0ne
09-14-2007 08:15 AM
The Si
Suspension & Brakes
03-12-2007 11:29 PM
ThrashSM
07-20-2004 10:58 AM
