I have a question about the obd2 d16a
I ordered this from HMO
http://www.hmotorsonline.com/shop/sc...age&item=30023
My question is, is there any special functions for the rocker arms. I read that under 3k rpm there is only one valve opening per cylinder on the intake side. Then after 3k all 16 are opening. I also read there was a egr and a vtec soliniod looking thing. All of which HMO says not true. I just want to get confermation so I can get it tuned right.also if you've had this engine. What did you think of it
Gracias
Gracias
Re: I have a question about the obd2 d16a
there's nothing special about it, it is pretty much a civic dx engine with a different intake manifold.
you paid a lot of money for a motor people are pretty much throwing away. you can get a d16y7 for well under $500 at any local junkyard.
Ya I did pay to much but I wanted a engine tht was going to be a GOOD used engine. Also the d16a's have a somewhat more aggressive cam witch gives it the 118 that it's rated at. Also if it's a slug then I'll throw the y8 head I have on it and get a Lil more pep in its step
http://www.onecamonly.com/showthread.php?t=3152
Turns out the intake is bigger all around but has iac on tb and no hole for it on the back.engine drives real smooth.
classciv
24
08-14-2005 09:12 AM
Terence
07-01-2005 01:12 PM
