i have a major problem
their is something majorly wrong because this is the 2 head gasket in 3 months can someone help please
stock d15 if that helps
and buns alot of oil is that the rings for sur
Re: i have a major problem (Throwdown)
Oil consumption depends primarily on two things: the valve guides and piston rings. If the valve guides are worn, or if there's too much clearance between the valve stems and guides, or if the valve guide seals are worn, cracked, missing, broken or improperly installed, the engine will suck oil down the guides and into the cylinders. The engine may still have good compression, but will use a lot of oil.
Link for you bro http://www.aa1car.com/library/oil_consumption.htm
Location: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
1 Post
Re: i have a major problem (tEKnics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tEKnics »</TD></TR><TR><TD CLASS="quote">Oil consumption depends primarily on two things: the valve guides and piston rings. If the valve guides are worn, or if there's too much clearance between the valve stems and guides, or if the valve guide seals are worn, cracked, missing, broken or improperly installed, the engine will suck oil down the guides and into the cylinders. The engine may still have good compression, but will use a lot of oil.
Link for you bro http://www.aa1car.com/library/oil_consumption.htm</TD></TR></TABLE>only those 2? what about valve seals?
1 Post
Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 »</TD></TR><TR><TD CLASS="quote">valve guide seals/valve seals, its almost universal terminology.
improper PCV can cause excess oil consumption.</TD></TR></TABLE> agreed thats why i said a few things
Re: i have a major problem (bluebeast)
to fix the antifreze problem the first time,
i think the heads woorpt
but ya thanx guys it really helps
Takumi Fujiwara
01-31-2006 07:52 AM
