i couldnt get the tranny on!
Hey guys, alright heres the deal, i have a 93 coupe with a z6 motor...im swapping the clutches but i cant get the tranny back on the motor....its still in the car...i didnt use a clutch alignment tool to get the clutch on the motor...could that be the reason. or could it be something else?
Re: i couldnt get the tranny on! (invboost)
try balancing the tranny on a jack and sliding it on instead of just trying to physically hold it and slide it on...... is that what you're doing??
Solbros Owns Me
Re: i couldnt get the tranny on! (Jswpstdoff)
unless you've done a few clutches before....it's probably not alligned. I would get an allignment tool. OR.....loose up the pressure plate bolts enough for the disc to move, pop the tranny in then remove(this centers the disc), and then torque down the pressure plate, and you should be good. Make sure your dowel pins didn't get all janked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by invboost »</TD></TR><TR><TD CLASS="quote"> i didnt use a clutch alignment tool to get the clutch on the motor...could that be the reason ?</TD></TR></TABLE>
that is exactly the reason. you need to align the clutch/flywheel in order to fit the tranny back on.
no, i am using a motor hoist...so all i need to do is use an alignment tool and everything should go smooth after that?
I think since you didn't line your clutch up with the line up tool was a big mistake because since the shaft in your tranny acts just like a line up tool, If you didn't like the clutch up correctly then you wouldn't be able to get the shaft on the tranny into the motor, I dunno if thats correct but thats my thought
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by invboost »</TD></TR><TR><TD CLASS="quote">no, i am using a motor hoist...so all i need to do is use an alignment tool and everything should go smooth after that? </TD></TR></TABLE>
yes. Otherwise, the tranny shaft will slide into the clutch disc, but won't pop into the pilot bearing
Re: i couldnt get the tranny on! (Emerika)
right on, but whats the deal with the bearing...does it just pop in place of the old one? and do i need to lube it up or something?
Solbros Owns Me
the bearing is hard to get out without the flywheel off. You'll need a pilot bearing puller.
You don't need to lube the shaft....I've never had a problem with it. I lube the throw out bearing though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">I lube the throw out bearing though</TD></TR></TABLE>
yea thats what im talking about...the throw out bearing...its just a direct replacemant for the old one right? it pops in its place and thats that? what do i lube the bearing with?
Solbros Owns Me
make sure you lock it onto the clutch fork correctly.
I lubed the inside of the bearing, the part that slides onto the shaft, Just used a little all purpose auto grease
how do i make sure that is it locked in correctly?? should it be able to spin left and right a little? and would axle grease be fine to lube it with?
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by invboost »</TD></TR><TR><TD CLASS="quote">how do i make sure that is it locked in correctly?? should it be able to spin left and right a little? and would axle grease be fine to lube it with?</TD></TR></TABLE>
it doesn't "lock in" persay....but it does slide over the shift fork, and you do have to play with it a little.
Re: i couldnt get the tranny on! (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi »</TD></TR><TR><TD CLASS="quote">Anti seize is what i use</TD></TR></TABLE>
You use anti-seize on the throwout/release bearing???? um might want to stop that practice.
If you've ever seen anti-seize after its sat for a bit, it hardens and becomes a very thick gel. You want a high-temp urea grease on the splines and the release bearing. Anti-Seize is a NO NO.
nocturnaldragon
04-30-2004 08:18 PM
