I am so sick of the HX being overlooked by the aftermarket!
[RANT]This is irritating, everytime I start to research either a turbo or a supercharger, I hit a wall beacuse these guys decided to smog legalize there stuff for every Civic except the HX. Come on, how can you over look the lightest coupe in the fricken group!!![/RANT]
Spade who is about to just give up. But hoping Jackson racing will give him some decent news.
Re: I am so sick of the HX being overlooked by the aftermarket! (Spade)
thats because on your motor is designed to run in a lean burn cycle all the time. lean=not good
just get a sohc vtec EX head,intake,manifold,ecu,tranny, u will then have a EX motor, and then u can find so much more
but do u see what im saying..that cylinder head/ecu combo is made to run lean, its a high mpg engine. either u go vtec or non vtec..not vtec-e..thats my opinion
Or stop being cheap and buy a B motor, there i said it, why go through all the headaches? Might as well just milk the 40 + mpg while you save your gas money to buy the new engine. If not when i buy MY B engine ill sell you my old POS D16Z6 Thanks
Re: I am so sick of the HX being overlooked by the aftermarket! (JaeOne3345)
Yes, I understand that and there is alo the thing where the "lean burn" goes away once the VTEC-E turns on.
AND even though I haven't verified the duration of both cams the HX has higher lift on it's cam on both the intake and exhaust then the EX.
Also, it is on the higher lift points (VTEC-E) at 3000 RPMs as apposed to 5500 like the EX.
EDIT: ROFLLMAO......I was just ranting guys. I have researched all the possiblities and I just refuse to accept the fact that I have to swap the engine........
[Modified by Spade, 8:06 AM 6/11/2002]
Re: I am so sick of the HX being overlooked by the aftermarket! (95civiccoupe31)
Re: I am so sick of the HX being overlooked by the aftermarket! (94HybridEx)
Tell him more about this "b-series" stuff....I don't think spade knows
EDIT: Then again.....some may just be blind and not consider who they are speaking to.
[Modified by Spade, 8:07 AM 6/11/2002]
no one said u have to swap the engine, just the head
ER I did.....dammit......
[Modified by Spade, 8:09 AM 6/11/2002]
95civiccoupe31,
If you have any questions on your "b series" let me know.....
Spade who 90% of the time will have the answer.
what are your goals?
TORQUE!!!! LOW END, Eat the tires for breakfast, lunch and dinner TORQUE.
Ok not tryin to be a smart ***, but who wants a headache?
spade, i suggest u look into 88-89 a1 teg pistons, y8 headgasket, arp headbolts, y8 head,y8 manifold,ex tranny, a plus side with the sohc vtec is that u can idle and daily drive the biggest ****** cams on the low cam profile, and have a monstrosity on the vtec lobes, be careful with valve clearances and the a1 pistons though. pick a fuel system of your choice, dyno dyno dyno, and lose some weight.
not even gonna argue with you dude, i know what a sohc turbo is capable of, but its seems like a big headache.
HRM, interesting enough.....but, I forgot to mention one more thing......California Smog legal If I don't change the block then they will smog it as a HX.
Isn't this fun? ROFL.
I am starting to think about just buying a drag turbo and taking it off when I need to smog. HRM. TOO expensive.
If only my lazy *** would just go and talk to the smog ref and figure out if swapping the B20Z's intake manifold for an LS manifold is legal. Since that swap would be about the cost of a damn turbo or cheaper......hrm. Decisions decisions decisions.
Re: I am so sick of the HX being overlooked by the aftermarket! (fowler)
NO SWAP!!! This is canada where we call our ex's si's!!! hehe or in spades case hx is a well....still an HX! hehe
V8 Power Baby!
V8 Power Baby!
Funny, at least I don't have a 70 lb piece of glass over my head.
Okay but still I hate the lack of head room (6'1" here)
