Hydraulic System?
Hydraulic System?
Okay, even after the clutch replacement, when you put the car in R and barely ease up on the clutch, the car begins to move WITHOUT touching the accelerator (and this is on level ground).
I've checked both reseviors that say "fill with brake fluid" and they're full. I can't see any obvious leaks.
What gives?
What gives?
Re: Hydraulic System? (LOABA)
i think thats fine, have you ever noticed that a car lurches forward when you kill it and its in a forward gear? as long as it doesn't move while the clutch is fully depressed your fine, its just starting to grab, your engine is still reving
just like eg93 said this is completly normal and happens in like any manual car. Not only will that happen in reverse but also in first. Your brake fuild would have nothing to do wit this at all. Thats actually a technique i use sometimes in very slow stop and go traffic. not sure but it prolly wears the clutch
