HX rims on 92-95 Si?
Old 07-05-2003, 10:53 PM
wizzards581's Avatar
Default HX rims on 92-95 Si?
will they fit??? last time i heard it doesnt... let me know again...
Old 07-05-2003, 11:00 PM
JV
Who?
JV's Avatar
Default Re: HX rims on 92-95 Si? (wizzards581)
You have to grind the calipers. If someone tells you different, they're a damn liar...
Old 07-05-2003, 11:38 PM
official honda whore
EARLdaSQUIRREL's Avatar
Default Re: HX rims on 92-95 Si? (JV)
i dont see why they wouldnt, hell i have vx rims on my 92 si and there only 13's
Old 07-05-2003, 11:59 PM
cxSOHChatch's Avatar
Default Re: HX rims on 92-95 Si? (coptzer)
i believe the si got bigger front rotors after 1994 but im not 100% positive
Old 07-06-2003, 12:03 AM
well it only got bigger rotors if it had abs i do believe, and then im sure you can fit a 14" rim when i can fit a 13" rim now
Old 07-06-2003, 12:42 AM
elwood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 &raquo;</TD></TR><TR><TD CLASS="quote">will they fit??? last time i heard it doesnt... let me know again...</TD></TR></TABLE>
What size are the stock wheels on a si? 14 inches
What size are HX rims? 14 inches
Why wouldn't they fit?
Old 07-06-2003, 12:48 AM
Solbros Owns Me
Evs-One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV &raquo;</TD></TR><TR><TD CLASS="quote">You have to grind the calipers. If someone tells you different, they're a damn liar... </TD></TR></TABLE>
I'm a liar
But seriously. All 92 and 93 hatches share the same front rotor size as all other Civics, so anything 13inch and over will fit.
In 94 and 94, ABS was an option, which had bigger front brakes then the other non ABS Civics.
I have a 94 Si without ABS and I run HX rims and have had VX on the front
Old 07-06-2003, 12:58 AM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
Here:
https://honda-tech.com/zerothread?id=491711
Old 07-06-2003, 02:17 AM
M-EJ1's Avatar
Default Re: HX rims on 92-95 Si? (INVALID)
For those of you with 95 EX Coupes that want to mount HX wheels, you will for sure have to grind on the caliper, even if you don't have ABS. My car was like this. I wouldn't even be able to fit VX wheels over my brake rotors.
BTW, just because both steelies and HX's are 14 doesn't mean ****. If you've tried to put an HX wheel on the front of a 95 coupe, you'll find that it's not the outer diamater of your rotor that's too big, it's the fact that the spokes of the wheel curve inward on the back side, effectively changing the "offset" of the wheel as it gets further towards the outside of the rim. This is the only place it will actually rub, so you have to shave down a small amount off of the vertical connector on the caliper.
Old 07-06-2003, 02:40 AM
Eskay@JDMCircle.com's Avatar
i had a 95 si with HXs on.. stuck right on no probs for acouple years til i took em off for a change of new rims.
Old 07-06-2003, 07:15 AM
JV
Who?
JV's Avatar
Default Re: HX rims on 92-95 Si? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
I'm a liar
In 94 and 95, ABS was an option, which had bigger front brakes then the other non ABS Civics.
I have a 94 Si without ABS and I run HX rims and have had VX on the front </TD></TR></TABLE>
Riddle me this Batman...
I have a non ABS 95 EX. One of my friends has a non ABS 93 EX. The HX's won't fit either without grinding...!?
Edit: Spelling
Modified by JV at 11:26 AM 7/6/2003
Old 07-06-2003, 07:34 AM
MAD ITR 55's Avatar
The EX has bigger calipers like the GSR's.My buddy has GSR calipers on his 93 Si and he had to grind his calipers to make them fit.They should fit over the stock Si calipers just fine.
Old 07-06-2003, 08:49 AM
Eee Pee's Avatar
Default Re: (V8s2shame)
Here's an idea.
Try it.
Old 07-06-2003, 09:16 AM
JV
Who?
JV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V8s2shame &raquo;</TD></TR><TR><TD CLASS="quote">The EX has bigger calipers like the GSR's.My buddy has GSR calipers on his 93 Si and he had to grind his calipers to make them fit.They should fit over the stock Si calipers just fine.</TD></TR></TABLE>
So the Si's have a smaller caliper all the way around (as in piston size and everything)?
Or is it just the "bar" that is on the EX/GSR caliper, that is absent from the Si calipers?
Old 07-06-2003, 10:13 AM
MAD ITR 55's Avatar
The rear brakes are the same size.The GSR/EX front caliper is larger than the Si far as piston size and caliper size.You cannot get just GSR front calipers and try to put them on the stock Si hub because they will not fit because of being a larger size.So when you try to upgrade to GSR's you have to get the whole hub assembly.
Old 07-06-2003, 11:03 AM
so with ABS HX wont fit and without ABS HX will fit?
Old 07-06-2003, 11:10 AM
Solbros Owns Me
Evs-One's Avatar
Edit: Spelling
Modified by JV at 11:26 AM 7/6/2003</TD></TR></TABLE>
we're not talking about coupes here
Old 07-06-2003, 12:44 PM
Status Sean's Avatar
i would think that they will indeed fit haha
Old 07-06-2003, 03:26 PM
JV
Who?
JV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V8s2shame &raquo;</TD></TR><TR><TD CLASS="quote">The rear brakes are the same size.The GSR/EX front caliper is larger than the Si far as piston size and caliper size.You cannot get just GSR front calipers and try to put them on the stock Si hub because they will not fit because of being a larger size.So when you try to upgrade to GSR's you have to get the whole hub assembly.</TD></TR></TABLE>
Ah i see. Thank you sir...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">we're not talking about coupes here
I know, but how else am i supposed to learn...
Mr_Moos
10
12-19-2006 03:44 PM
slowmovingegg
10-03-2006 11:54 AM
lovemyIntegra
08-15-2006 10:39 PM
B!^A@
07-30-2006 03:22 AM
MrEg
55
10-26-2004 10:13 AM
Quick Reply: HX rims on 92-95 Si?
