Quick YES or NO : will 13" rims fit on 92-95 "SI" hatch
lookin into buying the rota RB rims which only come in 13"
i know they fit the DX,VX,CX,HX but are the calipers in front of the Si bigger??
Re: Quick YES or NO : will 13" rims fit on 92-95 "SI" hatch (=GAMEOVER=)
serious????? 94-95 calipers are larger???
always thought 92-95 si calipers were the same size
Re: Quick YES or NO : will 13" rims fit on 92-95 "SI" hatch (mr_timluu)
yes they will fit............i have a 92 si and it rolls perfectly , but fortunately i upgraded to gsr so now i have no use for my 13"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_timluu »</TD></TR><TR><TD CLASS="quote">serious????? 94-95 calipers are larger??? </TD></TR></TABLE>
i said rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! »</TD></TR><TR><TD CLASS="quote">13's will not fit on the front of Si's. only in the back. </TD></TR></TABLE>
we are talking bout 92-93 right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch318 »</TD></TR><TR><TD CLASS="quote">i have a 92 si hatch 13 will not fit front</TD></TR></TABLE>
well you got ripped off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorEG6civic »</TD></TR><TR><TD CLASS="quote">yes it will fit cuz they come factory in 13in rims already, </TD></TR></TABLE>
negative 14" with dubcaps
i said rotors.
there are two diferent size rotors on civics. 9.5 in and a 10.2ish rotor
92-93 si's came with 9.5's you can get 13's on those
94-95 had the option of abs all abs fr rotors are 10.2 so you need 14' wheels
unless the 92-93 has the 10.2" rotors then it hsouldnt be a problem
i know i found a st of 10.2 in non abs spindles on a 93 ex coupe
it all depends on the rotor size
scarponze
scarponze
overrated.
Re: Quick YES or NO : will 13" rims fit on 92-95 "SI" hatch (zulued)
i have VX Front Calipers and GSR Rear Calipers with brembos all around and i use 13" VX wheels on track days no problem. I'm not sure how much bigger Si calipers are...
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zulued »</TD></TR><TR><TD CLASS="quote">there are two diferent size rotors on civics. 9.5 in and a 10.2ish rotor
scarponze</TD></TR></TABLE>
Interestingly enough, this guy is the first one in the thread to have correct information.
'92-95 Si without ABS had 9.5" rotors up front, and can use just about any 13" wheels.
'94-95 Si with the optional ABS had 10.3" rotors up front and used the same calipers as '94-01 Integra - thus, only a certain few 13" wheels will work (namely Lenso VPD 13x7.5, Panasport 3-piece 13xX, and I think Volk TE-37 13xX as well).
Re: Quick YES or NO : will 13" rims fit on 92-95 "SI" hatch (Targa250R)
well basically, you can always fix clearance with spacers or diff. offset wheels as mentioned.
be professional
Re: Quick YES or NO : will 13" rims fit on 92-95 "SI" hatch (93CivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI »</TD></TR><TR><TD CLASS="quote">92-93's are 9.5" - 94-95's are 10.2" (same as TEG...)
Wrong.
'94-95 EH3 without ABS still had 9.5" rotors.
Wrong.
Why don't you just get Panasport rims? Same style as the RB one you ordered.
http://www.panasport.com/street.html
Modified by chronodyne28 at 6:17 PM 10/16/2004
Re: Quick YES or NO : will 13" rims fit on 92-95 "SI" hatch (chronodyne28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chronodyne28 »</TD></TR><TR><TD CLASS="quote">Why don't you just get Panasport rims? Same style as the RB one you ordered.
Modified by chronodyne28 at 6:17 PM 10/16/2004</TD></TR></TABLE>
I'd assume because Panasports cost quite a bit more.
Re: Quick YES or NO : will 13" rims fit on 92-95 "SI" hatch (gamby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gamby »</TD></TR><TR><TD CLASS="quote">
I'd assume because Panasports cost quite a bit more. </TD></TR></TABLE>
Same style but they make them from 13 - 17 inches. He wouldn't have a problem putting them on then now would he?
I would trust Targa250R's information, he has busted out some unbelievable knowledge. He has always schooled some people on factory specs. To the original poster, I would refer to Targa250R's specs he has some superior knowledge of factory specs when it comes to civics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
'94-95 Si with the optional ABS had 10.3" rotors up front and used the same calipers as '94-01 Integra.</TD></TR></TABLE>
wrong. caliper on all civics are smaller then integras.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R33CIVIC »</TD></TR><TR><TD CLASS="quote">
If you say so man
If you say so man
ABS was not available for 1995 USDM Si hatchbacks.
be professional
Re: Quick YES or NO : will 13" rims fit on 92-95 "SI" hatch (Outrun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVER= »</TD></TR><TR><TD CLASS="quote">wrong. caliper on all civics are smaller then integras.</TD></TR></TABLE>
Then would you care to explain how the calipers in a '94-95 Si with ABS take the exact same pads (617 front, 374 rear) as '94-01 Integra non-R calipers?
And how about '94-95 LX/EX sedans with ABS? And '93-95 EX coupes with ABS? They also used the 617/374 pads.
Care to explain? Or are you just pulling information out of your ***?
