Hump problem during auto to manual swap
i am almost done with my auto to manual swap but that little hump under my car where the a/t shifter use to be is in the way. i dont have a dremel so i tryd drilling thru the weld points and that didnt do anything. after, i tried hitting it with a hammer. still nothing..
what are some methods to get this thing off?pls reply
Re: Hump problem during auto to manual swap (Dyce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyce »</TD></TR><TR><TD CLASS="quote">i am almost done with my auto to manual swap but that little hump under my car where the a/t shifter use to be is in the way. i dont have a dremel so i tryd drilling thru the weld points and that didnt do anything. after, i tried hitting it with a hammer. still nothing..
what are some methods to get this thing off?pls reply</TD></TR></TABLE>
hump? what hump? there isn't a hump where the auto shifter was. can you post pics?
Re: (slo6gen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo6gen »</TD></TR><TR><TD CLASS="quote">hes talking about the wind plate... i used a air gun with an air hammer... worked great </TD></TR></TABLE>
wind plate? i have a 93 dx that was once auto and i did a conversion. i don't remember a wind plate. and i don't remeber anything in the way either.
i know the manuals have a wind plate. but not the autos.
Re: (slo6gen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo6gen »</TD></TR><TR><TD CLASS="quote">yeah... it hangs down right above the cat... doesnt hang much but it does enough so the shift linkage will not be able to fully go up to the hole</TD></TR></TABLE>
hmmm...weird, i never came across the problem with mine. my shifter bolted up fine, it was cake!
Re: (94hondacivicvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec »</TD></TR><TR><TD CLASS="quote">yea so was mine but it was a 94 coupe. the OP must have a 96-98 or 99-00</TD></TR></TABLE>
ahh...well that would make more sense, something the OP neglected to mention.
yeah, mine is a 93 hatch.
Re: (slo6gen)
slo6gen is right.
http://img.photobucket.com/alb...0.jpg
pic of hump (plate)
http://img.photobucket.com/alb...3.jpg
pic of it cut
thats a pic taken off this forum. hit hangs down before the cat and is in the way of my shift linkage. i have a 00 coupe ex
pic of hump (plate)
pic of it cut
Re: (Dyce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyce »</TD></TR><TR><TD CLASS="quote">slo6gen is right.
thats a pic taken off this forum. hit hangs down before the cat and is in the way of my shift linkage. i have a 00 coupe ex</TD></TR></TABLE>
yea, you should have mentioned that you had a 00 civic. this whole time i was thinking 92-95 civic. which that hump is not there. damn, that sucks though.
good luck!
good luck!
Re: (Dyce)
I got mines off with a pry bar that has a blunt end so you can take a hammer to it. Was not doing so well at first but I gave it a good sharpening and It was much easier. Came off shortly after.
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
good luck! </TD></TR></TABLE>
Its still there even on 92-95. It guides the auto cables to there correct location.
Theres 2 spot welds that are behind the "bracket" that attaches to the bottom front of it. Have to take it off then you could get the other 2 welds then hammer and your set.
srt4pilot
05-28-2009 03:02 AM
