how to test for leak in tires?
well the other day mt psi was at like 8!!! i filled it up to almost the max and it looks like its getting lower, is there a way that i can put it in water or something to see where its coming from?
Re: how to test for leak in tires? (itr_eg)
ive use to deal with this **** all day i use to work at town fair tire i would inflate it to 35psi or so and spray soapy water onto it make sure to check the valve stem and the tire bead to make sure its not leaking from there eighter also dont stick plug it they suck and most likely it will end up leaking again. have it patched from the inside as long as its not to close to the sidewall you'll be all set
Re: (slamdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdcivic »</TD></TR><TR><TD CLASS="quote">just get soapy water and fill the tire up with air and then spray the soapy water on the tire and wait to see bubbles, and there's your leak</TD></TR></TABLE>
yes the ol' soap technique works good
Re: (sloz64now)
take the wheel off and dunk it in the pool..... that way you'll know where ALL the leaks are, should there be more than one.... i always get a weird look when i suggest that idea. i dunno why, it works really well....
'90crxSI
12
09-04-2006 03:48 PM
90JPRCRX
01-20-2005 01:52 PM
