How to stop the axle from moving when removing or putting on axle nut?
How do you guys remove or tighten back on the axle nut without the axle or hub moving on you. I will be using a 600lb impact gun on it to take it off but when putting it back on I plan on to torque it. How do I stop the axle from turning.
Modified by wdskuk at 5:11 AM 7/22/2004
Re: How to stop the axle from moving when removing or putting on axle nut? (wdskuk)
damn 600 lb impact gun? where did you pick that up from?
I think you could put the car in first gear and it should hold there.
Electrician
Re: How to stop the axle from moving when removing or putting on axle nut? (Luserkid)
[QUOTE=Luserkid]damn 600 lb impact gun? where did you pick that up from?
[QUOTE]
We sell 1,000 lb impact guns at Sears.
[QUOTE]
600 lb impac t ist very much.. it prob isnt 600 in reverse anyways.. and with an impact you dont need to do **** but pull the trigger..even that little pounded in tab will move itself with an impact.
The 600lb impact gun I got is made by Ingersol-Rand. The model of it is 2131QT. QT stands for quiet tool. I got this from Sears for close to 200 bucks. It's the blue impact gun if you go look at it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdskuk »</TD></TR><TR><TD CLASS="quote">How do you guys remove or tighten back on the axle nut without the axle or hub moving on you. I will be using a 600lb impact gun on it to take it off but when putting it back on I plan on to torque it. How do I stop the axle from turning.
Modified by wdskuk at 5:11 AM 7/22/2004</TD></TR></TABLE>
hand tighten the axle nut onto the hub. put the wheel back on, remove the center cap....
once the car is on the ground, there will be a load on it... now you can have somebody hold the break and you can do your magic
Re: How to stop the axle from moving when removing or putting on axle nut? (jdmsiR20)
those things come in handy when you need to break crank pulley bolt. That's the only thing that could break 2 of my friends crank pulley bolts.
stick a fairly thick screw driver inside one of the vent holes in the rotor, and the caliper will stop it from turning depending on the direction ya want it to go.
Re: How to stop the axle from moving when removing or putting on axle nut? (ADVANcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVANcrx »</TD></TR><TR><TD CLASS="quote">
stick a fairly thick screw driver inside one of the vent holes in the rotor, and the caliper will stop it from turning depending on the direction ya want it to go.</TD></TR></TABLE>
i like the way u think. imma have to keep this in mind for future reference.
just impact it on, why torque it, it's not like there's a preload on the bearings.
and the best impact on the market is the ingorsoll and rand T1, it has a 1000ft/lbs. of torque, and it's super light
Re: How to stop the axle from moving when removing or putting on axle nut? (dogfood)
wtf!? why mess with screwdrivers/other bullshit jamming it.. just use someones leg to push the brake pedal..
Re: How to stop the axle from moving when removing or putting on axle nut? (JL)
easiest way will be to put it in a gear and leave it like that it will hold the rotor
I'm in the process of putting a new d15 in my civic and to take the nut off we had to put it in gear and it worked just fine so i'm guessing it would do the same putting it back on...i'll know next saturday when we finish good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JL »</TD></TR><TR><TD CLASS="quote">wtf!? why mess with screwdrivers/other bullshit jamming it.. just use someones leg to push the brake pedal..</TD></TR></TABLE>
haha
anyways, you won't need to call someone out to help ya when it can be done it a matter of seconds. alrite later newb
haha
dynamo
13
11-14-2005 08:22 PM
EFM_ookie
16
08-14-2005 09:27 PM
