How to replace headgasket?
Old 06-24-2011, 11:47 AM
Pancho2193's Avatar
Default How to replace headgasket?
First of all, I see oil in the the radiator, and I'm no car genius but that sounds like a blown headgasket, or a leak. Is there possibly any other thing that could be before I start taking apart my head?
Is there any tutorial or write-up you would recommend on how to replace a headgasket?
Pancho2193 is offline
Old 06-24-2011, 11:48 AM
The Grumpiest
grumblemarc's Avatar
Default Re: How to replace headgasket?
https://honda-tech.com/search.php
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
grumblemarc is offline
Old 06-24-2011, 11:50 AM
Corksil's Avatar
what kind of car...
97 civic, with what motor?
Corksil is offline
Old 06-24-2011, 11:52 AM
Pancho2193's Avatar
Ooops I forgot to mention D16y8 completely stock.
Grumble thanks, I already looked in the FAQ and I can't find it. I've also searched I'm probably not searching right i'll try again.
Old 06-24-2011, 11:58 AM
The Grumpiest
Here's one.
http://hondaswap.com/general-tech-ar...ts-pics-71528/
Old 06-24-2011, 12:04 PM
Arthas's Avatar
Head gaskets are so easy. USE OEM ONLY. Those shitty auto parts head gaskets are made of foam and suck *****.
Mark the timing belt and cam gear in the same spot so when you slap the head back on, you have timing correct.
Disconnect everything from the head (sensors, all hoses, exhaust manifold, etc).
Loosen the timing belt from a 14mm bolt near the block. Slide the belt off of the gear.
Remove the valve cover then you will see ten 14mm bolts. These hold the head down. Loosen then by doing 1/4 turns. DO NOT REMOVE one bolt at a time because they are under high pressure and you will risk warping the head.
Use this order to remove the bolts
9 3 1 5 7
8 6 2 4 10
Install the new OEM head gasket and reinstall the head. Use the same sequence to tighten the bolts but do it in these torque specs
STEP 1 14
STEP 2 36
STEP 3 49
STEP 4 49 (Go through all of them again.)
Connect everything back to the head (exhaust manifold, hoses, sensors yadda yadda)
Remove the radiator cap, turn on the car make sure theres no leaks and it runs properly.
Bleed the cooling system and replace any missing fluid.
Arthas is offline
Old 03-15-2016, 08:21 AM
ReyesHonda's Avatar
Im about to change my headgasket also.. I have a honda civic 94 dx.. The headgasket blown and i see white smoke and stuff.. Was searching and found this here..also i went to youtube and found this guy with great tutorial step by step with 4 parts. Wish me luck lol
ReyesHonda is offline
Old 03-15-2016, 12:45 PM
Hysterically Calm
TomCat39's Avatar
This is a pretty old thread.
The accepted method here at Honda-Tech is to create your own thread with your car specifics and reference this thread by linking to it.
Old thread closed to be put back to rest.
TomCat39 is offline
B_Swapped93
12-17-2012 03:07 PM
protopro88
06-17-2011 02:17 PM
Mr_Bojangles
12-13-2004 07:22 PM
95civicSirCoupe
06-13-2004 04:23 PM
kyle h.
01-07-2003 03:50 PM
Quick Reply: How to replace headgasket?
