94 civic d15b7 high to low idel
Old 03-07-2010, 07:58 PM
kin6521's Avatar
Default 94 civic d15b7 high to low idel
i have a 94 honda civic hatchback .. it has a d15b7 motor ... the motor was running fine till i changed the intake manifold t a skunk2 proseris intake mani... and now when i first crank it the car runs fine but once it warms up it goes into like a high then low idel ... can anyone help or give me any sugestions ..
Old 03-07-2010, 09:02 PM
Former User's Avatar
Default Re: 94 civic d15b7 high to low idel
Vacuum or intake air leak. Check for a disconnected vacuum hose or a leaking IM or TB gasket.
Old 03-07-2010, 09:06 PM
kin6521's Avatar
alright will check first thing in the morning ... thaks and will let u kno what i find out .. thanks
Old 03-08-2010, 07:30 PM
kin6521's Avatar
i check all that and nothing .. everything is fine any other suggestions
Old 03-08-2010, 09:10 PM
1993eghatchy's Avatar
i had the same issue with the same motor when i first got my hatch..check everything from the TB to ivac make sure everythings where it goes and the bolts r all tourqued down an check the gasket itself if everything else seems fine
Old 03-09-2010, 03:17 AM
ChrisRogers's Avatar
Idle air control valve(IACV) Clean it/replace it and see if that works.
Old 03-10-2010, 04:29 AM
kin6521's Avatar
where is the iacv located wut does it look like
Old 03-11-2010, 12:20 AM
Hope this helps
Old 03-11-2010, 12:27 AM
crxpenguin's Avatar
check the thermo valve under the throttle body if the spring is broke inside it causes a surging idle.
Old 03-11-2010, 10:14 AM
kin6521's Avatar
thanks everyone for the help but i think i got it fixed now .. i replaced the TPS and adjusted timing and got everything straight .. but thanks for the help wid everything everyone ...
Old 03-11-2010, 03:18 PM
Glad I could help and it's great that you got your car running! :D
Old 03-24-2010, 06:42 AM
kin6521's Avatar
does anyone know if i can put a d16 si trans into my car ... i have a d15b8 block wid a d16y8 head .... just want to know if i can put the d16si trans on it before i purchase it
Old 03-26-2010, 09:45 PM
crxpenguin's Avatar
good to hear you got your car up and running again
hun8504
12-26-2012 09:37 AM
singlecammin
01-20-2011 07:20 PM
Roofrack
04-07-2009 07:42 PM
ludacole
08-29-2004 03:38 PM
extrmeboost
03-18-2003 09:36 PM
Quick Reply: 94 civic d15b7 high to low idel
