Vacuum leak?
Old Apr 5, 2009 | 10:25 PM
Roofrack's Avatar
Default Vacuum leak?
ok im stumped ive checked all the hoses and changed the pcv valve in the oil catch canister sprayed carb cleaner around the vacuume lines checking for a change in the idle and i got nothing but when i press my hand real hard over the TB it bogs a very small amount but keeps on going my idle is stuck at 1500 i changed the TPS sensor and calibrated it to .5 closed 4.5ish open and change the IACV and still nothing the motor is a 96spec GSR with type r pistons the compression is 180 across the board and im using a blox intake manifold
i also checked 2 see if the leak was coming from brake booster cuz ive heard of it happening i just took plyers to the hose 2 c if there was a cahnge and got nothing
QUESTIONS
can there be a crack on the intake side of head or in the intake manifold gasket that would be making it this bad
and anyone have any ideas what i should inspect for?
Old Apr 6, 2009 | 09:08 AM
HondaAllDay's Avatar
Default Re: Vacuum leak?
check your intake manifold gasket and change it, also try your TB gasket. And bleed your radiator for air
Old Apr 7, 2009 | 07:36 AM
Roofrack's Avatar
kk ill check it out thanks i changed my tb gasket when i swaped the tps but maybe i screwed somthing up and didnt notice it gona check it out asap
Old Apr 7, 2009 | 07:42 PM
any luck?
singlecammin
Jan 20, 2011 07:20 PM
almostboostedgsr
May 11, 2009 08:21 PM
93SiPrelude
Feb 24, 2008 10:39 PM
ilu
Apr 19, 2006 03:08 PM
98itr0448
Jul 10, 2004 03:17 PM
