how reliable are mini me swaps?
Re: (andoxviii)
All in the build from what I've read, like the LS/VTEC. Do your homework, and don't cut corners, and you ought to be fine.
Re: (andoxviii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi »</TD></TR><TR><TD CLASS="quote">All in the build from what I've read, like the LS/VTEC. Do your homework, and don't cut corners, and you ought to be fine.</TD></TR></TABLE>
very true, you need that bottom end a **** hair stronger however
Re: (denniscoles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denniscoles »</TD></TR><TR><TD CLASS="quote">because i'm thinking d16y8 head on a d15b7 block.</TD></TR></TABLE>
With that combo you will need a adjustable cam gear to get the timing right.
I went with a y8 head on a y7 block on a 92dx, made things alot easier.
good luck.
good luck.
Re: (k0rupt_ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k0rupt_ed »</TD></TR><TR><TD CLASS="quote">wow realy **** didnt know it shortened the life whats the reasoning behind it?</TD></TR></TABLE>
I would like to hear that also, nearly the same as a stock y8 just a slight change in compression.
idriveadelsol7
16
07-04-2005 02:28 PM
