How long can my CV joint last
Old 01-14-2003, 09:48 PM
Simple's Avatar
Default How long can my CV joint last
i am going to see if it needs to be replaced tomarrow, it started popping tonight, but the boot is good. just started tonight, how long you think itll last.. (axle on a b20Vtec) would u recommend takin it real easy from now on?
Old 01-14-2003, 10:02 PM
careawholelot's Avatar
Default Re: How long can my CV joint last (Simple)
the rubber boot on mine got cut and grease came out, but there is no noise or vibration at all, been like this for about a month waiting tell i can hear a knocking noise then i will replace the axle.
Old 01-14-2003, 10:26 PM
HondaGSR's Avatar
If its already popping, ticking, knocking, making noise in general its to late you have to get an AXLE a boot wont fix the noise now!!
[Modified by HondaGSR, 2:27 AM 1/15/2003]
Old 01-14-2003, 11:11 PM
madtownhonda's Avatar
Default Re: How long can my CV joint last (HondaGSR)
Mine lasted 3000 miles like that. It started to sound really bad so I decided to change it. Doing it tomorrow.
Old 01-15-2003, 02:24 AM
Banned
blykins's Avatar
Default Re: How long can my CV joint last (madtownhonda)
My passenger side axle is slinging a little grease. I cant find out where its coming from though, it seems to be in tact. I guess i'll take out the axle and examine it closer. Its been re-booted before.
Old 01-15-2003, 04:23 AM
94si94cx's Avatar
Default Re: How long can my CV joint last (blykins)
I've been driving my car on clicking axles for god knows how long. I'd guess probably about 6000 miles if not more.
Old 01-15-2003, 05:06 AM
VTECVillain's Avatar
Default Re: How long can my CV joint last (tealeh2)
Mine clicked on my VX for over 2 years. I waited to replace them when I decided it was time to do the B18C1 swap.
Old 01-15-2003, 05:39 AM
HondaGSR's Avatar
Default Re: How long can my CV joint last (VTECVillain)
Well all i can say is that all you guys are driving on borrowed time!! Why chance it? That not really something that i would want in my mind at 100 + on a mountain road, or rush hour traffic. IMO
Old 01-15-2003, 06:02 AM
My VX wouldn't do 100+ on a mountain road unless I drove off the side of a cliff.
Old 01-15-2003, 07:34 AM
Mr Miyagi's Avatar
Does anybody know how difficult it is just to replace a cv boot and not the whole axle? Mine just started spewing grease out, not sure how long its been doing this for though?
Old 01-15-2003, 08:02 AM
freakin_eLRoD's Avatar
Default Re: How long can my CV joint last (Mr Miyagi)
It isn't very hard, but its time consuming. If your outer boot is torn, you still have to remove the inner boot to gain access to the outer boot. Its messy as hell but if your axles aren't knocking just the boots can be replace. IMO 60 bucks and a lifetime warrantee at autozone is the way to go.
Old 01-15-2003, 08:08 AM
Mr Miyagi's Avatar
Default Re: How long can my CV joint last (powerBan.est1990)
that's what I'll probably end up doing anyway. thanks yo
Old 01-15-2003, 08:49 AM
AWD: Jeff's Avatar
i think you should get them fixed right away. both of my axles started to click and i took it forgranted. both of them gave away. i couldnt steer left or right. and right after i shut of my car. my car would not go anywhere. its better you fix it now then suffer later on.
Old 01-15-2003, 11:20 AM
Default Re: How long can my CV joint last (Dohc93hatch)
Just fix it. Today I changed the axle, transmission fluid, ball joint boot. All that took about an hour, so it's not time consuming. Better safe than sorry.
Old 01-15-2003, 11:23 AM
ej1civic's Avatar
both of my rubber boots are cut. Knocking like crazy. I seriously need to change my axles!
Old 01-15-2003, 04:49 PM
HondaGSR's Avatar
i dont agree, yes you can do it that way, BUT, cutting off the the ripped outside boot, (if that is the one the is ripped) once its off, you can knock off the outter joint. but i would only advise this if you know what your doing. But just wanted to give another way to do it.
Old 01-15-2003, 05:07 PM
PBTemplar's Avatar
I replaced both axles for $144. Its not that expensive, just do them both.
Old 01-15-2003, 05:26 PM
Simple's Avatar
Default Re: How long can my CV joint last (PBTemplar)
well i found out what it was, it wasnt the CV joint after all, it was my lower cusco bar just looser than my X girlfreind's ***. tighted, and pops went away
tundra2000
04-08-2011 11:54 AM
iwanaturboteg
04-29-2008 11:16 AM
WRTEG
08-18-2004 02:15 PM
GReddy SI
12
07-17-2003 04:07 AM
Quick Reply: How long can my CV joint last
