How to jack up 96 Civic?
Old 07-27-2005, 10:25 AM
LeonardDB's Avatar
Default How to jack up 96 Civic?
Anybody got any tips on jacking up the Front end with a floor jack? I couldn't find any lift points besides behind the wheel wells. My previous Toyota and Ford had a support beam running down the center of the car. While we're at it, how to jack up the rear of the car?
Old 07-27-2005, 10:26 AM
Imperious: Mod of Valor
JDM-EJ1's Avatar
Default Re: How to jack up 96 Civic? (LeonardDB)
There should be 2 two hooks on either side of the frame. There each off to the side, that's where I jack mine up from.
Old 07-27-2005, 10:28 AM
Luserkid's Avatar
Default Re: How to jack up 96 Civic? (JDM-EJ1)
His talking about from the cross member.
From what ive found out about honda's is that if you dont make/get a custom one they usually bend and/or break. So i hate lifting from there.
If you must, the spot it right on the rad. support on the bottom. Youll see a spot that looks out of place thats it. Also i used to lift from the tranny, it lifts the motor then the car.
Old 07-27-2005, 11:02 AM
kkim's Avatar
https://honda-tech.com/zerothread?id=127216
Old 07-27-2005, 11:04 AM
kleanlscivic's Avatar
Default Re: How to jack up 96 Civic? (kkim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=127216</TD></TR></TABLE>
that be the sweet spot
Old 07-27-2005, 11:27 AM
LeonardDB's Avatar
KKim, is that pix you referenced the knobby looking spot under the radiator? I saw that point but passed on using it. It doesn't look like much metal for support. I'd damn sure not want to crack my radiator, what an idiot I'd feel like.
Old 07-27-2005, 11:58 AM
CivicMike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LeonardDB &raquo;</TD></TR><TR><TD CLASS="quote">KKim, is that pix you referenced the knobby looking spot under the radiator? I saw that point but passed on using it. It doesn't look like much metal for support. I'd damn sure not want to crack my radiator, what an idiot I'd feel like.</TD></TR></TABLE>
take off your bumper and youll see how that spot is the entire front frame rail for your car.......also the back can be jacked on the round tow hook in the middle rear of the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">His talking about from the cross member.
From what ive found out about honda's is that if you dont make/get a custom one they usually bend and/or break. So i hate lifting from there.</TD></TR></TABLE>
ive never had a problem lifting from the front under rad, rear under tow hook, or either side at the seams.
If you must, the spot it right on the rad. support on the bottom. Youll see a spot that looks out of place thats it. Also i used to lift from the tranny, it lifts the motor then the car.</TD></TR></TABLE>
use the 'rad support' (FRAME) to jack the car and not the tranny unless you want to break your mounts supporting your car with your tranny.
Old 07-27-2005, 12:04 PM
Nova_Dust's Avatar
Behind the front bumper, on the driver side. No need to remove anything. Knee down, tilt your head and you will see it.
Old 07-27-2005, 12:18 PM
kkim's Avatar
Yes, thats the front jacking point. check out this thread (towards the middle of the post) with pictures from the helm's service manual, which shows you where to jack from (front, sides and rear). if it's good enough for Honda, that's where I'd jack from... and do.
https://honda-tech.com/zerothread?id=548700
Old 07-27-2005, 01:05 PM
JDM-EJ1's Avatar
Default Re: (Nova_Dust)
Awesome, thanks for clearing this up guys.
Old 07-28-2005, 05:32 AM
LeonardDB's Avatar
Default Re: (JDM-EJ1)
Thanks everybody for the posts. I've been working on different model cars for over 30 years. That lift point under the radiator is the dinkiest lift point I ever saw. I never would have used it without the advice. My Haynes Civic manual only mentions the lift points behind the wheel wells.
Old 07-28-2005, 05:35 AM
xEnderx's Avatar
Default Re: (LeonardDB)
I usually hit mine on the side jack points....takes longer, but its how I've always rolled.
Old 07-28-2005, 08:06 AM
allmotorb16jay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nova_Dust &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
when I jack mines up.. I usually put a thick flat peice of wood in between the front jack point and my jack... I do this so incase the front jack point won't get pushed in...
Old 07-28-2005, 10:17 AM
Nova_Dust's Avatar
Highly unlikely that's gonna happen. You are reducing the friction between metal parts by introducing a wood piece. That to me, is more dangerous.
Old 07-28-2005, 10:48 AM
Evanmb44's Avatar
no kidding...i would just stick w/ only the jack right there
si937
05-26-2007 10:55 PM
roosterman
11-28-2006 07:49 PM
draztk_tendncies
64
09-03-2006 04:48 PM
EKmonsta
12-03-2004 12:55 AM
slate13530
08-29-2004 06:41 PM
Quick Reply: How to jack up 96 Civic?
