How to identify a b-series between a d-series shift linkage
I got a jdm b18b swap in a trade with this guy. After going through the engine I found he gave me the wrong ecu, motor mounts, and the water pump was wrong (bolts didn't line up, idk) So I got all the right parts and I swapped in into my 95 hatch and the shifter seems too short and it fights me going into every gear, but it will go into gear!
I tried doing some research into finding the specs between the two and i didn't come up with anything useful. And info you guys have would be much appreciated.
Re: How to identify a b-series between a d-series shift linkage
What engine was in the hatch before you swapped the B18B in?
Did the B18B come with its own shift linkage? If you're trying to use D-series shift linkage, it will not work.
It had the stock d15b7. The linkage I'm using now came with the swap, and I got rid of my old linkage so I can't really compare the 2 side by side.
I can't identify B-series shift linkage by sight but you need to know what kind of linkage you're using. Judging by all the other wrong **** that guy gave you, it could be the wrong shift linkage.
That's what I'm thinking but I want to make sure before I buy a new one. It bolts up fine but it shifts like poop
Seagull Management
A D-series linkage wont bolt up at all. The stabilizer bar is different at the transmission end. B-series has a big hole to go around an aluminum boss on the transmission. D-series has a small hole for a bolt to go through.
From the sounds of things you have a '90 - '93 Integra linkage (they're a little bit shorter than '94 - '01)
