How do i tell the difference from the OBDII B16A and the OBD1 B16A...
This guy is selling me his B16A...and he claims that it is a 2000 motor...i want to check visually to verify this...can anyone please help me...
Khoi
Khoi
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (RedlinedVTEC)
The way you can tell what year it is, is that the '96-up- if you look at the timing belt cover, on the right side of it. There will be a wire going behind the crank pully. That wire is for the #1 posission senser. Also, the injector plugs snap in, instead of the '95-lowers, they have a wire clip that holds them to the injectors.
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (WykidEG6)
can u guyz give me visual pics...of this please..i heard something about the manifolds lookign different..from the 2000 motor and the older b16a....
Someone give me more info please,
Khoi
Khoi
Guest
Posts: n/a
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (Sohc Driver)
OBD 0 B16A - white plugs on the dist
OBD 1 B16A - gray plugs (2) on the dist
OBD 2 B16A - gray plug (1) on the dist
You can also look at the head stamp. It should say (9|9) or (0|0).
Also, the 96+ B16 US version will have a VIN plate on the block by the bottom of the header, and a VIN plate on the tranny by the block code bar.
Also, if you get the entire swap, the 99-2k SI has a 1pc wire harness that should be long enough to reach inside the passenger compartment, and will have the ECU plugs connected directly to it.
HTH
HTH
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (B18C-EJ1)
I'd try looking on the head, if there are stock headers you may have a little trouble looking past the heat sheild.
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (CdnSI)
what do u mean...by plug(1) Plug (2) on the distributor...and also i remember seeing some differences on the intake manifold...from the 2000 motor and the rest...does anyone else know about this....
Khoi
Khoi
this is your best bet.
keith
keith
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (kwil666)
A quick check would be to look at the valve cover if it is a JDM motor.
SiR I=big dohc small vtec
SiR II=small dohc big vtec
if its an USDM motor look on the block it will have a number after the engine code
(ie)B16A3 USDM SI motor
I suggest looking at the block.
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (captainJDM)
if it's a legit block...just run the vin plate on carfax....if the vin plate is missing...you should start to question your purchase.
OBD 1..one O2 sensor in front of cat...OBD 2..u have a O2 sensor infront and behind the cat
Guest
Posts: n/a
Khoi
Khoi
2 Plug, meaning there are 2 plugs for the DIST
can someone please get me a pic of some sort.....of the headstamp where it says 00 and 99
Guest
Posts: n/a
Well, lookie what I got..............
Look above the #3 cylinder port
The year is the far left circle in 2 digits (#|#)
[Modified by B18C-EJ1, 8:11 AM 12/20/2001]
