How do i tell the difference from the OBDII B16A and the OBD1 B16A...
This guy is selling me his B16A...and he claims that it is a 2000 motor...i want to check visually to verify this...can anyone please help me...
Khoi |
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (Sohc Driver)
If it's a US motor just look at the engine code on the block.
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (RedlinedVTEC)
The way you can tell what year it is, is that the '96-up- if you look at the timing belt cover, on the right side of it. There will be a wire going behind the crank pully. That wire is for the #1 posission senser. Also, the injector plugs snap in, instead of the '95-lowers, they have a wire clip that holds them to the injectors.
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (WykidEG6)
can u guyz give me visual pics...of this please..i heard something about the manifolds lookign different..from the 2000 motor and the older b16a....
Someone give me more info please, Khoi |
OBD 0 B16A - white plugs on the dist
OBD 1 B16A - gray plugs (2) on the dist OBD 2 B16A - gray plug (1) on the dist You can also look at the head stamp. It should say (9|9) or (0|0). Also, the 96+ B16 US version will have a VIN plate on the block by the bottom of the header, and a VIN plate on the tranny by the block code bar. Also, if you get the entire swap, the 99-2k SI has a 1pc wire harness that should be long enough to reach inside the passenger compartment, and will have the ECU plugs connected directly to it. HTH |
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (B18C-EJ1)
I'd try looking on the head, if there are stock headers you may have a little trouble looking past the heat sheild.
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (CdnSI)
what do u mean...by plug(1) Plug (2) on the distributor...and also i remember seeing some differences on the intake manifold...from the 2000 motor and the rest...does anyone else know about this....
Khoi |
this is your best bet. keith |
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (kwil666)
A quick check would be to look at the valve cover if it is a JDM motor.
SiR I=big dohc small vtec SiR II=small dohc big vtec if its an USDM motor look on the block it will have a number after the engine code (ie)B16A3 USDM SI motor I suggest looking at the block. |
Re: How do i tell the difference from the OBDII B16A and the OBD1 B16A... (captainJDM)
if it's a legit block...just run the vin plate on carfax....if the vin plate is missing...you should start to question your purchase.
OBD 1..one O2 sensor in front of cat...OBD 2..u have a O2 sensor infront and behind the cat
what do u mean...by plug(1) Plug (2) on the distributor...and also i remember seeing some differences on the intake manifold...from the 2000 motor and the rest...does anyone else know about this.... Khoi 2 Plug, meaning there are 2 plugs for the DIST |
can someone please get me a pic of some sort.....of the headstamp where it says 00 and 99
Well, lookie what I got..............
http://www.nrg-racing.com/images/tec...ild/head10.jpg Look above the #3 cylinder port The year is the far left circle in 2 digits (#|#) [Modified by B18C-EJ1, 8:11 AM 12/20/2001] |
