How do i remove fenders in a 5th gen hatch?
I tried searching and i didnt find anything...
How do i remove the fenders on a 5th gen hatch? yeah i know i should get a helms manual
Location: Why so you can pretend like youre interested, FL/OK
Re: How do i remove fenders in a 5th gen hatch? (MilanoRex)
This is from memory from two years ago so...
description is one side of car
There should be three bolts that need to be removed under the hood, there is another bolt towards the front near the corner light. There should be one that is visible after the sideskirt is removed which will allow easy access to it and I believe there is one in the top opening of the door, where the door meets the top of the fender near the windshield.
Hope this helps cause I'm rusty.
Re: How do i remove fenders in a 5th gen hatch? (SHAUNTS99)
correct but i think there are 4 bolts on the top of the fender so making it 7 in total. you'll need to use an extention and open the door just right for the bolt located on the top by the door you will need to remove the corner lens for the bolt on the front and you will need to remove the side skirt of the bolt under it good luck
[Modified by ill phil, 3:38 AM 12/31/2002]
2fastcivic
02-09-2002 05:31 AM
