How do i hook up my Auto-Meter shift light???
I just got a shift light from a friend, the pic is below. I just need to know where the wires go.
It has 3 wires coming out, a red, a black, and a green one. I am thinking the red is power and black is ground and the green is what??? and where does it go???
And i have no tach in my car, so dont flame
Thanks for the help in advance
Here is the pic:
Here is the pic:
Re: How do i hook up my Auto-Meter shift light??? (R0bCee)
first of all, I have never installed a shift light.
since we have hot and ground, what else is missing that would make this work? check out a wiring diagram and splice it into the tach signal on the gauge cluster harness.
the green is the signal wire, it goes to the blue wire in your engine bay(it is the tach wire) you install little yellow pills into the shiftlight to control your shifting point. it doesn' t automatically know when to shift, the pill is what connects the circuit.
Re: How do i hook up my Auto-Meter shift light??? (SpydiR)
But i do not have a tach, its a CX hatch....
Is there a tach wire behind the cluster anyways?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R0bCee »</TD></TR><TR><TD CLASS="quote">But i do not have a tach, its a CX hatch....
Is there a tach wire behind the cluster anyways?</TD></TR></TABLE>
yes it is near your dizzy in your engine bay, or you can tap into it near your clutch resiovior.
http://hp.autometer.com/instru....html
you have the second one(Pro-Shift Light) DL the 397F.pdf file
your welcome!
Modified by R33CIVIC at 11:39 PM 11/19/2004
your welcome!
the clusters are plug and play, so there has to be a wire in the cluster harness. I have a '93 cx and installed an ex cluster and had to do no wiring. why go to the engine bay if you don't have to?
Re: How do i hook up my Auto-Meter shift light??? (A_RU_BA)
oh and i think off of my head there is two blue wires, i beleive its the blue with white? not to sure, been a lllllllllllooooooooooong time since i hooked up one of those >.<
