Shift Light Installation??????s
Old Dec 28, 2001 | 10:18 PM
BeanRacer's Avatar
New User
Default Shift Light Installation??????s
I purchased a used Autometer Shift light with no instruction booklet. There are three wires that I need to attach. Green, Black and Red. Which goes where? Any Help Please?
Old Dec 28, 2001 | 10:23 PM
Mike M's Avatar
Founding Member
Default Re: Shift Light Installation??????s (BeanRacer)
Im going to guess, Red is positive, Black is ground and Green goes to Tach signal (Which you can tap on the back of the gauge cluster)
Maybe someone with one can verify it though
Old Dec 28, 2001 | 10:27 PM
BoM's Avatar
BoM
RED - ignition
BLACK - ground (anything metal of the body, to a bolt)
WHITE - is a dash light...from the back
GREEN - the actually tach reading....get it from the tach termanal at the distributor
or what mike said intercepting it at the back of the cluster......which is a light blue wire on the middle harness...not sure though....find some wiring diagrams in a helms or haynes (free at pepboys)
[Modified by BoM, 2:29 AM 12/29/2001]
Old Dec 28, 2001 | 10:41 PM
BeanRacer's Avatar
New User
Default Re: Shift Light Installation??????s (BoM)
The green wire on the shift light connects to what color wire on the distributor? Where can I find the ignition wire?
[Modified by BeanRacer, 2:44 AM 12/29/2001]
Old Dec 28, 2001 | 11:23 PM
Mista Bone's Avatar
D Tranny Guru
Green goes to Blue tach wire. You can connect to it at either the service connector on the LF shock tower (easiest), behind the gauge cluster, or off the distributor.
Going to the factory service connector is by far the easiest.
Old Dec 28, 2001 | 11:28 PM
Darin D.'s Avatar
Default Re: Shift Light Installation??????s (Mista Bone)
or you could just hit the rpm signal wire at the ecu? seems a lot easier than running wire into the engine bay.
this is an obd2 diagram.
obd1- http://www3.honda-perf.org/community...ec/sfcv_h2.jpg
Old Jan 1, 2002 | 09:59 AM
BeanRacer's Avatar
New User
Default Re: Shift Light Installation??????s (Willis)
Thanks for all the info. I installed the shift light with all your advice but it seems that the light only works in first and second gear. I almost blew my motor up waiting for the light to go off on third gear. My motor reached to 9500 RPM and no light went off. I glad I have an upgraded valve train. Any suggestions why my light doesn't work in third or fourth gear. Jay
Old Jan 1, 2002 | 10:02 AM
Flux's Avatar
No light is going to be a replacement for common sense...
Old Jan 1, 2002 | 10:05 AM
Kamin's Avatar
Default Re: Shift Light Installation??????s (Flux)
yea dont rely on a light to tell you when to shift, if your engine is sreamling louder than normal shift
Old Jan 1, 2002 | 01:28 PM
Mista Bone's Avatar
D Tranny Guru
going through the dash is way easier!
No wire to lay under the carpet/through the dash for 6 feet.
Once you see where the plug/grommet is, it is really easy.
Cln94EG1
Mar 23, 2008 01:28 PM
Hatch It
Nov 19, 2004 07:50 PM
HONDA_TYPE_R
Oct 31, 2004 01:45 PM
LsPower
Dec 17, 2002 06:02 PM
crashtest Sonny
Jun 23, 2002 11:22 PM
