How do I change the Air Conditioner Belt?
Title says it all, basically.. I need to throw a new belt on.
My car is a 1992 Honda Civic VX with a B16A2 engine in it, I have a P30 ECU.
Guides are nice, pictures are even nicer
H-T White Ops
Step one: Remove your P30
Step two: Install a chipped P28
(I have no idea why you added your ECU info for a thread asking for how to replace a belt)
If I remember right the power steering belt needs to come off as well as the lower side mount thing as well as the engine mount on that side. You'll needa jack under your engine to support it while you work on th belts (might as well to the power steering one while you're at it.
Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">Step one: Remove your P30
P30 is the del Sol B16 ECU, why would you reccomend replacing it with a chipped ECU? That's like replacing a Z6 head with a Y8 head; no real point, and questionable legality.
H-T White Ops
Re: (fdavie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fdavie »</TD></TR><TR><TD CLASS="quote">
P30 is the del Sol B16 ECU, why would you reccomend replacing it with a chipped ECU? That's like replacing a Z6 head with a Y8 head; no real point, and questionable legality.</TD></TR></TABLE>
You obviously didn't see the sarcasm. Show me where the fact that the OP has a P30 ECU in his car has anything to do with being able to change out a BELT.
mtrtbldr
06-10-2017 04:56 AM
rhdins
07-06-2006 09:27 PM
