how to convert to ABS?
Old 11-30-2011, 08:18 AM
khmoe's Avatar
Default how to convert to ABS?
I have a EJ8 96' with rear drums and want to upgrade.
I have a set of rear trailing arms with disc brakes from an EG6 but it do not have ABS.
What parts do i need to convert to ABS in the rear.
I need rear hub new, so i buy a new set with abs rings.
Can i use the old heatshields and cut a hole or do i need to buy some new?
Can i use front or rear abs sensors from ej6/8(have a set )
Tried to search, but could only fint that i should buy si rear trailing arms, but i have a set. only missing some parts i think.
Live in Norway so shipping is expencive for heavy parts, so hope i only need som new parts.
Old 11-30-2011, 08:45 AM
EK9
Dc4LsTeG's Avatar
Default Re: how to convert to ABS?
You'll need the abs module also, and I'm pretty sure you have to use different brake lines so they can go to the module...it sounds like a lot of work
Old 12-01-2011, 08:41 AM
khmoe's Avatar
The car has ABS, so no module needed.
I think i need:
Brake lines
Rear hub bearing w/ABS (need to buy)
ABS sensor(proberly need to buy)
Brake Shield with whole for ABS or modifie the old one.
Any one else know?
Old 12-01-2011, 08:45 AM
kyden's Avatar
i would just get an integra trailing arm, everything is already there otherwise you would have drill and tap the holes for the abs sensor to mount on the civic trailing arm in addition to the bearing.
Old 12-01-2011, 09:17 AM
nealnanoHX's Avatar
I would just remove the ABS and save weight.
Old 12-01-2011, 09:30 AM
EK9
Dc4LsTeG's Avatar
Thought you many there was no abs on it right now
Old 12-01-2011, 09:47 AM
Wrona's Avatar
some people actually like safety save weight lol what it weighs like 15lbs maybe?
Old 12-01-2011, 09:48 AM
Oh look, I can change this
deschlong's Avatar
To clarify for the TL;DR crowd .. also b/c I was a bit confused.
EJ6 (6th Gen) HAS ABS already, but with drum brakes in rear.
EG6 (5th Gen) rear trailing arm parts w/ disc brakes that he bought, DO NOT have ABS.
OP wants to mount EG6 discs onto his EJ6 and hook up ABS. What parts does he need to do this? NOTE: He is in NORWAY, so getting parts from an Integra is basically impossible.
Old 12-01-2011, 09:53 AM
EK9
Dc4LsTeG's Avatar
I know they came with abs, I thought he meant his was previously removed..but back to the question, not sure about the eg6 ones, but what about em1 rear trailing arms?
Old 12-01-2011, 10:01 AM
deschlong's Avatar
OP: Here are the parts for a 1994 USDM Si Hatchback Rear Disc Brake with and without ABS. Different part numbers *should* indicate whether that part is specific to ABS.
EDIT: Also added diagrams for BRAKE LINES and REAR LOWER ARM. That should cover it.
Old 12-04-2011, 11:42 AM
khmoe's Avatar
The trailing arm with disc brakes came of a civic without ABS.
So it seams like i have to get:
ABS sensor and make some holes to mount it.
Modify or buy new brake shields.
New hub/bearing with ABS ring.
New brakes lines (i have )
Old 12-04-2011, 11:59 AM
deschlong's Avatar
You might be able to reuse some ABS parts of your previous drum brakes. Have a look before you buy.
Old 01-17-2013, 03:32 PM
my74honda's Avatar
uh yeah that 15lbs is 2hp (abs units actual weight is 22 lbs)...you can negotiate its worth but the way i see it every bit of power i can get out of my 4 banger is worth it, as far as safety,, the abs units are installed for people that have no experience driving, just like rev limiters and the new cut your fuel off at 100mph bull crap.
DROP THE ABS UNIT ITS USELESS HEAVY AND UGLY!!!!
Old 01-17-2013, 03:37 PM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
scottso990
07-26-2011 05:25 PM
c1_sleeper
Suspension & Brakes
10-16-2008 07:10 PM
ED9man
03-14-2007 01:42 PM
Quick Reply: how to convert to ABS?
