How to change my pads on my 98 ek with gsr read disk?
I was trying to change the pads and the rotors on my 98 ek with gsr rear disk. I could not get the damn thing open. Anyone no how? I search and no luck. I need help. I'm stock right now and i need my car.
Re: How to change my pads on my 98 ek with gsr rear disk? (10kracer)
let me understand this correctly...are you trying to use GSR brake pads, on a 98 civic? if so it will not happen becuase civic and integra brakes are totally different.
What exactly are you trying to open?
-Disconnect the e-brake cable
-remove the lower 12mm bolt on the caliper
-swing the caliper up and remove the pads.
If you are doing rotors too
-remove the two 17mm bolts on the back of the caliper brackets.
-slide the caliper bracket off
-use an impact driver to remove the two screws holding the rotor in place.
-slide the rotor off.
If you dont know how to do something as easy as brakes, perhaps you should seek help somewhere else, besides H-T. Like maybe a friend or somebody you know that show you how to do it.
Or just pay someone to do it.
ok, when i did my swap, i used c-clamps to push the piston back so you can apply the new brakes pad...i hope this help
Re: (Slopoke)
I know how to change my brakes. I took of the bootom and top 12mm bolts. I also took of the 2 15mm bolts. Is just doe not moving. I dsont know why. But thanks for your help.
Re: (10kracer)
Your ebrake isnt on, is it?
Inorder to get the caliper to swing up, you need to remove the ebrake cable.
Or I think you can unbolt the top and bottom 12mm bolt and slide the caliper off the caliper bracket without removeing the ebrake cable.
98dxhatch
10-30-2003 06:20 AM
