how can I remove the antenna cabling so I can install my flush antenna piece over where the antenna
I searched and found this: https://honda-tech.com/zerothread?id=1975167
But does anybody know how to do this on a 97 civic ex coupe or have any pics? I already looked around and traced the black cabling, but I can't find the area where the lead goes from the outside cable then back to the radio so I can unscrew that part of the antenna cabling and pull it out... Help?
Re: how can I remove the antenna cabling so I can install my flush antenna piece over where the ante
Here's what I did. Removed the two top screws that are holding on the antenna plastic plate. Pulled the whole thing out about 2-3 inches so I could see a little better.
There was a metal strap that connected to one of the holes that one of the two screws go into and I popped that off with needle-nose pliers. Then I could pull the antenna and cabling off of the plastic antenna plate and I just tucked it all back in.
Used the Honda Genuine Black Plastic block plate I got from JHPUSA.com and screwed it in. Looks awesome and I can still use the radio if I want, or if I sell the car and the person wants it back how it was (OEM).
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">I searched and found this: https://honda-tech.com/zerothread?id=1975167
But does anybody know how to do this on a 97 civic ex coupe or have any pics? I already looked around and traced the black cabling, but I can't find the area where the lead goes from the outside cable then back to the radio so I can unscrew that part of the antenna cabling and pull it out... Help?</TD></TR></TABLE>
The pictures I posted in that thread would work the same for a '96-'98 coupe. The only difference is the wire going to the rear from the antenna is for the '99-'00 sedans and the radio on the '96-'98s would have a cabel that goes to the slave mounted above the cupholders, which this cable has nothing to do with your antenna.
H-T White Ops
Re: (SIC-CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIC-CIVIC »</TD></TR><TR><TD CLASS="quote">pics. of flush ant. piece or O.E hondae part ??? never heard of it or seen it.</TD></TR></TABLE>
Same part for a 5th gen. They're commonly sold online.
Re: (NOFX)
Yep I bought them from JHPUSA.com, have fun checking it out.
http://www.jhpusa.com/catalog/...99302
or see:
or see:
