Distributor problems on my d15b any ideas
Old 09-22-2004, 09:15 AM
KiD Fr0m Da 516's Avatar
Default Distributor problems on my d15b any ideas
I installed a JDM d15b Motor into my '94 civic. Sometimes at low rpm it would bog and want to die. Now it won't start at all and there is no spark to the plugs. There is still power to the distributor. I was wondering if anyone had similar problems. I'm assuming that the distributor is may need a coil, maybe i can try a cap and rotor i dont know its very wierd please let me know if you have the same promlem or had.
Old 09-28-2004, 04:37 PM
hopsta's Avatar
Default Re: Distributor problems on my d15b any ideas (KiD Fr0m Da 516)
i guess i was having the same problem. Hooked up a a new stereo sytem in 95 civic LX and ran fine after the stereo was hooked up. I have a 1000 watt amp.
The next day after that it just wouldnt start...it cranked like it wanted to but just didnt. All relays and fuses are good. Alt, and starter are good also.
My only option is the distributor coil and distributor. if you find out anything let me know also.
Old 09-28-2004, 04:38 PM
ej1 pilot's Avatar
what dizzy are you running?
Old 07-28-2023, 11:30 PM
Ad khan's Avatar
Sir change distributer and adjust throtal screw but going to die again was having same problem
Jhicks
01-28-2012 07:08 PM
ILuvMyJdmDc4
11-27-2007 04:43 AM
HoNdAmAn29
09-04-2004 08:49 AM
SI_niki
06-15-2004 07:54 AM
Quick Reply: Distributor problems on my d15b any ideas
