How to adjust clutch pedal?
Re: How to adjust clutch pedal? (dannis.)
i heard that you can adjust the ckutch pedal from the inside of the car next to the clutch pedal.
Re: How to adjust clutch pedal? (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch »</TD></TR><TR><TD CLASS="quote">you can adjust the clutch by turning the plunger/rod that attaches ot the pedal.
go under the dash.
find the clutch
find the rod attached to the pedal
loosen lock nut
turn the rod (not sure which direction raises/lowers engagement mabey someone else will chime in with that answer,or just test it and find out)
tighten lock nut
test.</TD></TR></TABLE>
go under the dash.
find the clutch
loosen lock nut
tighten lock nut
mikeycivic
05-23-2007 02:34 PM
jdmcivicferio
11-12-2003 06:02 AM
