HONDA TROUBLE - hit pot hole and engine has cut out
Old 08-29-2007, 10:48 PM
kyle45's Avatar
Default HONDA TROUBLE - hit pot hole and engine has cut out
hit a severe pot hole last night and my engine cut out immediately after the impact, the engine hasnt started since. The engine never hit the ground, is not leaking oil and i cant see any damage.....
has anyone got an idea of why the engine would have cut out due to the impact, or how to get the engine restarted?
the engine is a b18 dohc vtec
any knowledge appreciated!
thanks
Old 08-29-2007, 11:13 PM
smileycvc's Avatar
Default Re: HONDA TROUBLE - hit pot hole and engine has cut out (kyle45)
Sounds like something got disconnected.
Old 08-29-2007, 11:21 PM
kyle45's Avatar
Default Re: HONDA TROUBLE - hit pot hole and engine has cut out (smileycvc)
possibly mate, but i was thinkin it could possibly by a safety mechanism where the engine automically cuts the power in the event of a crash but in this case a pot hole impact..... is this possible and is there any way to over ride this and reset the engine?
Old 08-30-2007, 12:41 AM
smileycvc's Avatar
There is no such failsafe. Does the car turn over anymore or anything?
Old 08-30-2007, 01:41 AM
EFM_ookie's Avatar
does it even crank over???
Old 08-30-2007, 02:09 AM
2000siturboR's Avatar
Default Re: HONDA TROUBLE - hit pot hole and engine has cut out (EFM_ookie)
heres an idea check your battery it was loose and got disconected
Old 08-30-2007, 04:57 AM
B18bEG6ick's Avatar
Default Re: HONDA TROUBLE - hit pot hole and engine has cut out (2000siturboR)
check you ground. it could be possible that it got ripped off when it hit the pot hot. i say tranmission ground.
Old 08-30-2007, 05:10 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like something got disconnected.</TD></TR></TABLE>
I know some cars have a fail safe. It shuts off the fuel pump if there in enough impact. There is usually a reset switch on the inside near the rear strut.
Old 08-30-2007, 06:31 AM
muhaMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000siturboR &raquo;</TD></TR><TR><TD CLASS="quote">heres an idea check your battery it was loose and got disconected </TD></TR></TABLE>
Old 08-30-2007, 07:54 AM
smileycvc's Avatar
Default Re: HONDA TROUBLE - hit pot hole and engine has cut out (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">
I know some cars have a fail safe. It shuts off the fuel pump if there in enough impact. There is usually a reset switch on the inside near the rear strut.</TD></TR></TABLE>
Hondas dont.
Old 08-30-2007, 06:20 PM
B18bEG6ick's Avatar
you are thinking about fords, its called an interia switch. honda's don't have that.
Old 08-30-2007, 06:43 PM
polything's Avatar
check batt and grounds :thumbs:
Armstrong57
29
09-16-2007 11:44 AM
kyle45
09-01-2007 05:59 PM
Quick Reply: HONDA TROUBLE - hit pot hole and engine has cut out
