(Question) How to keep P/S with GSR swap?
I have a 2000 Ex I'm trying to swap a GSR into. I am told that a CRV A/C bracket will allow me to keep the A/C and everything will bolt up.
I am also told that a power steering bracket (or 2) from a B16 will allow me to keep my P/S.
My question is:
Am I correct in assuming that the parts I need are numbers 3 and 6 in the following diagram?
If so, what is the most cost-effective means of obtaining these parts? Honda, Autozone, etc? I could keep searching the forums, but I need it/them by Friday. And should I have a part number?
BTW, I've searched but I've found no pictures or part numbers of what I need.
My question is:
Re: (Question) How to keep P/S with GSR swap?
if you cant get them, just shave a little of your headlight. its dumb way to go, but when your running out of time its also the easiest and most cost efficient.
for the psteering, you will need the donor gsr pst pump and P72 top bracket and p54 bottom bracket. for the ac, you will need the delsol b16 ac bracket aka the P54 ac bracket, all items are available at your local honda dealer, teh p54 ac bracket is cheapest on ebay at $115 shipped and you have to hunt around for the pump and brackets, its usually easy to find the pump on ebay but the brackets are hard to find, they are $60 a piece for the bracket at the dealership... I got a pair of top and bottom brackets for sale if you are interested $50 plus $15 shipping to cover paypal fees, I can set up an ebay auction for you if you are interested. I have over 800+ feedback on ebay. let me know, thanks
to keep your ps with a gsr motor you need a b16 p/s and to keep ac in your car you also need a 2000 si ac bracket . i went thru this same problem. and it was a pain in the *** to find a p/s pump but good luck
99-00 SI p/s pump and the top p/s bracket must be from the same code on the head.
madman604
14
10-14-2003 05:16 AM
