Honda civic 98hatchback
Hi All
I have a couple of problems with my honda that i am hoping to find info on.
First of all the SRS, airbag sensor light will not go off since i changed the car battery, is there anyway to reset this or just get rid of the sensor light altogether.
Also i have the old reliable honda civic problem with regards to the electric windows sticking. The drivers side has come of the rails and is actually on the outside of the seal. It has also split the seal so i need to replace it.
Does anyone no what is the correct name for this seal and were is the best place to source it.
Any help would be much appreciated , thanks
Re: Honda civic 98hatchback (ek4_b16a)
there is a certain type of spray lubricant that you can apply to the edges of your windows to help it slid better! I did it on my 99' si and it works 100x better than it did before...If anyone remebers the lubricant name plz post it!
dont let autozone or whatever do it 4 u
diy & learn
so u dont have to rely on others
u should have learned this the first day u became a member on ht
Modified by tha_badguy at 1:44 PM 3/7/2007
diy & learn
Re: (tha_badguy)
any cell your car throws can be reset by simply disconnecting the battery i believe. If it comes back on within 1-5 miles or so...Its for a reason and it should be either checked at the nearest honda dealership or you cant blink test it with a 16 gauge wire!
bob1973
17
06-17-2004 05:42 AM
