homemade oil catch can??
OK i am a cheap poor SOB, i am looking into making a oil catch can, i want something that will work (no steel wool inside) and that will look have desent.
I was thinking of using a fuel filter from auto zone or something, any one have any ideas if that will work or not? or have a better idea?
Thanks
Thanks
Re: homemade oil catch can?? (spencer00si)
unless your car is FI there is no need especially if it is a street driven car only. won't help. spend your money elsewhere. If you do want to do this my advice is to buy a Greddy catch can (they seem to be the best bang for the buck).
Re: homemade oil catch can?? (EleanoR)
heh i was bored one day and i too decided to make a home made oil catch can.
its not finished but so far i have the actual can built out of clear 1/4 inch plexi glass. it looks great and has held cold oil for about 1 month now and has held hot oil for a few hours with no problems at all. now when i get around to it i have to make holes for the fittings and find a way to mount it.
it is about 6 inches tall and 4 inches wide the top and bottom are glued on with a special epoxy that my buddys glass sho uses and thats why i had to test it with motor oil to see if the oil would break down the epoxy and it held up perfectly i stuck a few pieces of steel wool into it before we epoxied it and we drilled a small plugable hole to pour the oil in it.
im thinking about getting some of those anodized 90 degree angle fittings for the hoses that go to it i also got clear reinforced hoses for that cool look from the hardware store. all i really need to do is mount the fittings make them seal then find a way to make a bracket for the can and walah a super jdm catch can from me to the little **** on ebay
Re: homemade oil catch can?? (B16A EH2)
em, i really dont have the resources for the plexi glass one, i was thinking more along the lines of a fuel filter that is already made.
Re: homemade oil catch can?? (Inigo Montoya)
Do you think this would work,you could build it for less than $10 easy,just use silicone,let me know what you think, i might try it.
Re: homemade oil catch can?? (civictypenos)
just put some oil in it and let it sit for a month or 2 to see if the oil will eat the silicone or plastic if it dosnt it looks like a great start if it eats it try some diffrent sealent
damn that is a pretty good pic there i could use some caps for the top and bottom and drill out the rest.........maybe paint it black or something
thanks man
thanks man
rayzian
16
08-17-2007 06:48 AM
eg6abuser
02-22-2004 06:24 PM
onyx00
07-13-2003 04:03 PM
