Hit bump car shut off
Old 07-06-2004, 05:17 PM
Ej1_coupe's Avatar
Default Hit bump car shut off
I was driving through town today and went over a sewer cover. After I hit the sewer cover my car shut off/ stalled. As i pulled over i shut off the car and restarted it, it would start then the RPM's would drop and stall the car out again. I repeated this like 4 times. After the 4th time i restarted again and it ran like a champ. This only happened one time before and that was in december.
My question is why would it do this? To stiff of a ride and something just hit to hard and caused the car to shut off? No CEL came up, though I wish maybe it did. Thanks for the help.
Car- 95 civic Ex- I/H/E. - D16z6
Thanks.
Old 07-06-2004, 05:28 PM
2lua's Avatar
Default Re: Hit bump car shut off (Ej1_coupe)
how heavy is your key chain? try to drive your car with one key and go over bump and see if it shut off.
Old 07-06-2004, 05:36 PM
Ej1_coupe's Avatar
Default Re: Hit bump car shut off (2lua)
I only have a key and my alarm controller on a key ring.
UP
Old 07-06-2004, 05:38 PM
seppuku's Avatar
bad battery or loose connection
Old 07-06-2004, 05:39 PM
2lua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej1_coupe &raquo;</TD></TR><TR><TD CLASS="quote">I only have a key and my alarm controller on a key ring.
UP</TD></TR></TABLE>
check your grounds and battery conntection
Old 07-06-2004, 05:40 PM
Luserkid's Avatar
Had the same **** happen to me. And now (about a month or so later) it shuts off whenever it wants and im starting to throw a code 15 (ignition). Somehow when i bottomed out on a curve in the road (not a dip you know when the road on the freeway goes down then up) it fucked up my ignition now the car wont start. Next time the car dies look to see if your throwing a code. Good luck.
Old 07-06-2004, 05:44 PM
Ej1_coupe's Avatar
Default Re: Hit bump car shut off (Luserkid)
Thanks. Ill check all my wires and grounds tomorrow. Hopefully it was just a fluke agian. Its been about 7 months since its done this and after that point had been running strong. Good luck to you too Luser. Thanks.
hondastrtracr
03-10-2007 04:55 AM
blks2k3
04-05-2005 05:45 PM
scrap1ngsr
03-16-2005 08:50 PM
sleepin91teg
14
07-05-2004 09:48 AM
b16ahybrid
11-06-2003 06:08 AM
Quick Reply: Hit bump car shut off
