highway RPM's
Re: highway RPM's (grandtheftlunchbox)
i have a d16z6 engine and at 70mph i hit a little less than 3000rpm on 5th gear, does that help? But i have a dx trans, i don't know how different it will be on the si trans
Re: highway RPM's (Kinfer)
i know the Si has shorter gearing, so it will be higher than the DX. i guess ill have to start calculating. haha.
Ah no worries, the 5th on the DX and Si were the same from the transmissions I've compared (I'm in market for a 5-speed swap). Should be the same, could be different depending on year of transmission, of course.
[edit to not bump old post: Right, I forgot about final drive.]
Modified by Davus at 3:23 AM 9/2/2008
Re: highway RPM's (Davus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kinfer »</TD></TR><TR><TD CLASS="quote">i have a d16z6 engine and at 70mph i hit a little less than 3000rpm on 5th gear, does that help? But i have a dx trans, i don't know how different it will be on the si trans</TD></TR></TABLE>
The Dx trans has longer gearing, you will not be doing under 3k at 70mph with and si trans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davus »</TD></TR><TR><TD CLASS="quote">Ah no worries, the 5th on the DX and Si were the same from the transmissions I've compared (I'm in market for a 5-speed swap). Should be the same, could be different depending on year of transmission, of course.</TD></TR></TABLE>
That doesn't mean the transmissions are the same.
Op with and si trans you should be doing about 3500-4k going 70 mph. If its gas your worried about It's not that big of a deal.
I have a y8 running on a y5 ecu with a 95 si trans and I still get 40 miles to the gallon with no spirited driving.
Location: ....................................................................................................
Re: highway RPM's (gibsanez)
at 65 you are crusing at 2900 to 3 grand and at 70 your just crusing at around 3100 or 3300?
DirtyD777
02-10-2006 04:01 PM
civicwagonman
10-18-2002 06:40 AM
