High Compression d-series
#76
Re: (silent-chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silent-chris »</TD></TR><TR><TD CLASS="quote">gaskets from autozone are not that good of quality i would recomend a cometic or a honda gasket</TD></TR></TABLE>
and do not listen to this. a felpro Y8 gasket will be more than sufficient for your application. if you want to spend more on a gasket, feel free.
#77
Re: (lohatch)
i dont care if autozone gaskets do suck, it will last as long as i need it too.i only need em to last me like.... 6 months to a year at the most. and if it blows ill still have a reliable motor, im not getting rid of my dx motor.
#78
Re: (ubercerealkiller)
I know that using d16a1 pistons in a b15 block the piston will sit 3mm to low. I was curious if it is safe to have the block shaved 3mm? and just use the stock rods? I didnt know if that would make the timing belt to lose? I had my prelude block shave like 40 thousandths but i dont know what that is compared to mm and i didnt know the limits on the d15.
#81
Seagull Management
Re: High Compression d-series
12.05:1 keeping everything else stock. Here's a handy compression calculator if you want to try out some other combinations.
http://www.zealautowerks.com/dseries.html
ZedEx
10
06-12-2005 02:37 PM
YOSOLO CRX
13
11-13-2003 08:53 PM
