hey dragIIcivic quick question
whats the best time u ran with your car with the d-series turbo? just curious cuz i know someone who might turbo his d-series and wanted to know what the d-series could do. i mean i saw your site and 14.8 is ok but i was figuring u would've been faster is that your best time?
[Modified by sohc_boy, 3:56 PM 9/27/2001]
Re: hey dragIIcivic quick question (sohc_boy)
the 14.8 was my best time....BUT
it was at a aweful track, the motor had a blown headgasket, and it was a terrible run....
I burned out through 1st, and 2nd, and hit the rev limiter in 3rd
I only brought it to the track that one time....I am confident that the car was worth low 14 second runs or better....you have to understand just how bad that run was....it was at 9psi, and the MAP sensor fell off at somepoint during that run causing my car to stall out just past the finish line....I still don't know how I managed that run
Re: hey dragIIcivic quick question (DragIIcivic)
well that explains alot. when my car was turbo'd w/ the greddy kit i was pretty confident it would've run low 14's. i was just figuring that the kit u are running is much bigger and puts out much more power than the greddy. thanks for the reply. so u are going to a b16 now?
New User
Re: hey dragIIcivic quick question (maxim_force)
I am currently building a D16Z6 for a turbo. I am fully building(sleeved, pistons, rods, head work, machine work) I am hoping to run 12's on this setup with an F-MAX turbo kit. I plan on getting 2 extra injectors and plumbing all four of them into my intake manifold to help with the fuel dispersion. I am hoping that this setup will net some really good HP for a SOHC. If this setup doesn't do it then I'm gonna switch out the injectors and run a Hondata system.
hybrider
10-22-2002 02:33 AM
hybrider
10-19-2002 08:12 PM
