helped to my 93 eg hatch.
HELPED!!! HELPED!!! to my 1993 Honda civic!!!
I was driving on E. And was headed toward a gas station. Motors started shakened a little and losing power when acclerate, i can fell it. I thought it was just because the gas is on empty. As i put a full gas it still does the same thing. Came home. Next early morning i drove to work. The car engine lights came on, plus motors shake badly, losing power when acclerate. If i go pass 40-45 mph the car wouldn't increase speed faster no more. It sounds like when your on neutral and stepping gas. Drove it to my folks house. My dad and brother helped check the car out. My dad said that the problem is; running out of clucth, bad spark plugs & wires, distributor, clucth lever. But i have checked everything is fine. If clucth is out then i can't drive it at all or no engine check light should come on. If no spark from plug or wires then i wouldn't be able to drive. My brothers did this ecu check thing, and he said that it is #16-meaning iac something, but plus this 6 small little flash light flashing from dash speedometer. Which he had no idea. So far i checked for vacuum leaks, spark from plugs and wire, distributor, clucth, antifrezze, radiator, motor oil, tranny oil, 02 sensor, v-tec sensor, fuse inside/ out, battery failers, electric problems, fuel pumps, fuel hose if leaked, and pvc sensor. Stilled haven't found out why, please telled me if you guys know whats really wrong with it. Please be specific. Car has been out too long not to drive for about a month now.
Modified by lil_jess at 10:52 PM 5/25/2005
headrec*
13
10-28-2010 06:17 AM
Questy
07-06-2005 09:23 PM
01LSTeggy
02-16-2003 11:42 AM
