Help timing light what mark do i use?????
Old 02-10-2013, 06:10 PM
EG-SIXV-TEC's Avatar
Post Help timing light what mark do i use?????
Help Timing Light what mark to use????
i just replaced my distributor because its hella leaking, and the coil started to go bad. when i removed the dizzy i marked where the rotor was. it was at number one spark plug. when i installed the thing i put it on the same way it came off with the new dizzy.
motor a d15z1
So i jumped the ecu, checked the timing w/timing gun. i see the white line that is fartest to the firewall and three lines that is together facing front.
There are a total of four lines in all on the crank pulley.
what is the correct timing light to set the mark inline to????
i tried the white line fartest from the other three it seem to bottom out not to even come close to the mark.
what line do i use im confused?????
EG-SIXV-TECView Public ProfileSend a private message to EG-SIXV-TECFind More Posts by EG-SIXV-TECAdd EG-SIXV-TEC to Your Contacts
EG-SIXV-TEC is offline
Old 02-10-2013, 06:15 PM
Former User's Avatar
Default Re: Help timing light what mark do i use?????
Duplicate thread closed.
Former User is offline
EG-SIXV-TEC
02-11-2013 01:31 AM
hondachris1994
07-29-2008 11:48 AM
boomersz
03-16-2007 10:36 AM
kholmes
05-24-2004 07:01 AM
91crx but i heard vtec
11-18-2003 04:18 PM
Quick Reply: Help timing light what mark do i use?????
