HELP...Swap not starting...
I recently bought a 4door civic with a bad motor for cheap...I purchased a from a dealer with paper work and warranty for it. Long story short, i put the new engine in (D16y7) and the car is having a hard time starting. All the plugs are in, lines are hooked up, its getting fuel, getting spark, compression is 150 accross the board, and the only check engine light being thrown is for secondary O2 sensor, which shouldnt make a difference. The motor has started, but for whatever the reason, it will only start with the incorrect firing order and it will run really shitty. Im stumped as to what it may be...any help would be tight. thanks
Re: (Syndacate)
so far as i know...Timing is set and under waranty so i didnt touch it...The dizzy might be messed (cause thats the only thing i could think of..) and the comp test is damn near perfect. All my plugs are throwin spark...so i may as well change the dizzy and see what happens.
jspecwhore
43
05-11-2015 07:40 PM
