HELP WITH STATE REF. BAR'd questions! 92 with obd2 gsr PICTURES INSIDE!!!!! INFO NEEDED~~~
Re: HELP WITH STATE REF. BAR'd questions! 92 with obd2 gsr PICTURES INSIDE!!!!! INFO NEEDED~~~ (Kang
BUMP for great detailed questions! Somebody help him!
question #1
one of those hoses connect to the PURGE CONTROL SOLENOID on the intake manifold which is on ur picture 3..the other hose connects to a 2way valve.
question #2
Map sensor..NO u do not need to hook up a hose..your eg should have a map sensor b4 so look up on that..
question #3
that is the PURGE CONTROL SOLENOID..one of those goes to the evap canister and one goes to a tube on the intake manifold..looking at ur intake manifold picture its the tube right under the intake air temp on the right side.
question #4
not sure wut the top plug is but it might be an extra plug u dont need to hook up..the bottom one might be the reverse light or maybe a 02 sensor..not so sure
question #2
question #3
question #4
As long as I dont have to take out any more Metal Gears
#4 looks like a dizzy plug
And here is a vac diagram for GSR
I dont think its a dizzy plug becuase the car runs/starts fine witout that being hooked up, but I have to now becuase I think the ref. well not pass it being unplug. Any one else out there with this harness? what should I do? cut it and hide the extra plug ? Thanks for the help so far.
QUESTION: #3 so where does #1 hose go and where does #2 hose go. I want to make sure and be correct.
How does the map sensor look on a eg firewall and where on the firewall is it located?
Thanks so far guys.
Thanks so far guys.
Re: (Kangolbrand)
i purchased a oem honda manual from ebay for like 14 bucks shipped do yourself a favor and try to find one they are amazing some guys sell the **** on disc for adobe format aswell you would find every answer perfectly in there plus the torque specs for bolts you never knew you had
did you happen to do a obd2 gsr swap into an eg hatch? cause that thing looks an awful lot like my car.... i replaced the stock intake manifold with a skunk unit......looks familiar.
I aready brought a manual at autozone for the gsr motor but its really no help ... pictures suck! and I dont want to spend another 20 for a civic manual just to see where the map sensor is located... im sure someone here has a picture/diagram. Thanks so for guys
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">did you happen to do a obd2 gsr swap into an eg hatch? cause that thing looks an awful lot like my car.... i replaced the stock intake manifold with a skunk unit......looks familiar. </TD></TR></TABLE>
ya, its a obd2 swap. Do you have the same harness as in the picture? whats the extra plugs for?
