Help with Shift Linkage Please...
Hello could someone quickly tell me if this piece http://www.ebay.com/itm/221024889460...ht_3483wt_1034
would work on my 94 Honda Civic coupe Vin information is below. I already ordered the part above so if someone could tell me quick so I could cancel if needed thanks.
http://www.decodethis.com/Default.as...EJ1230RH509449
Re: Help with Shift Linkage Please...
The VIN you entered has an invalid check digit. The check digit is a value encoded into the VIN in order to protect against altering VINs illegally. Since the check digit is invalid the VIN that you entered is not the correct VIN for your car.
VIN doesn't really matter, and quite frankly shouldn't be posted publicly like that. What I said still holds true. Assuming you either have a B, or are putting in a B, it should work. My only hang-up is that A) the part looks different than what Hasport shows on their site, and B) it's actually more expensive than buying it directly from Hasport.
tour de france turbo
07-20-2003 06:20 PM
