Help on Removing Rear Main Seal
I have the flywheel off and thought I would replace the rear main seal but it is a pretty tight fit in there. I thought I would ask before I did anything stupid if any of you have experience removing the seal. I have a seal puller tool that looks like a little pick but I didn't want to start ripping it out and damage the motor on accident, any insight would be greatly appreciated. Thanks.
Re: Help on Removing Rear Main Seal (elmo908)
The seal puller will not damage the block if you are careful. I have had to destroy the seal almost everytime I replaced one. You are worrying too much.
Re: (elmo908)
if you pry it out make sure that whatever you use you point the end of the tool to the block side, if you scratch that side, not a big deal, if you scratch the crank, you'll be puttin another seal in it and fixn the crank
* B A N N E D *
Re: (19slocivic97)
i take out the seal holder while doing it, just not to damage the crank, i had to destroy the seal everytime i take it out, and you really have to work the new seal in there
Re: (spork motorsports)
take a drill and make a tiny hole in the seal, take your pick and start picking. MAKE SURE NOT TO SCORE THE SURFACES, or it will leak.
Yes i was screaming.
Re: (DeadEnd9009)
just take the 5 or so 10mm bolts holding the whole rear main cover off dude. once thats off , use a hammer and screwdriver to beat the old seal out , and use the old seal to beat the new one in. simple. make sure new seal sits flush.
91crxturbo
09-01-2006 09:38 PM
Cuong-nutz
12-22-2005 11:52 AM
