HELP!! Posible Vaccumm Leak! :S
hello
I've been feeling rare symptoms in my Honda Civic 95 coupe D15b Vtec as having a vaccun leaks
symptoms are
Rough Engine Idle
Engine Hesitation
Imprecise Transmission Shifting
Poor Acceleration
symtoms are described in this link
it said those symtomps are caused by a vaccun leak.. i feel those in my car..
but i cant find the leak.. can this symtomps really mean a vaccun leak and if is can u tech me how can i find the vaccun leak.
my cars Has no CEL
Thanks
symptoms are
Rough Engine Idle
Engine Hesitation
Poor Acceleration
my cars Has no CEL
Thanks
Re: HELP!! Posible Vaccumm Leak! :S
VERY CAREFULLY while the engine is running spray around with some carb cleaner/quick start. If you have a leak it should get sucked in and change idle.
Keep in mind that if you light your car on fire I'm not responsible... I would have a fire extinguisher close by.
Look at this for more info.
http://www.youtube.com/watch?v=9CPqbaSgcok
Hmmmmm... How long has the car been doing this?
Could it be ignition timing? Not sure on that someone confirm that
Maybe a misfire, or a lean/rich condition?
Some of those vacuum leaks are hard to find though, I wouldn't completely rule it out.
There was a vacuum leak on my civic, i spent hours looking for it. I just took it to my friends shop and one of the guys there had a weird stethoscope thingy and found the leak in a few minutes. It was next to the throttle body. My car was idling funny as well. BTW i have a 98 civic. just my two cents.
Today some rare things happen.. my car was checked by an honda electricist and he found my tps plug has 2 pin swaped the green white wire and the yellow white wire, he swap the wires together and all the problems seems to be fixed... the only prob i still have is rough idle but this only happen when the car is on operating temperature, when cold idle i just fine.. what can i check fot rought idle only when car is on operating temperature
Check your compression if that's good do a major tuneup. I would suspect a vacuum leak if any work had recently been done to the intake.
nicklp60452
07-14-2008 02:53 AM
LilCivic04
09-09-2005 11:28 PM
