HELP!!! Passenger side window acting up!?!?!
On my 96 civic coupe, the passenger side window not working properly. The window wont roll down but if i hook up direct power to it form the battery it will roll down and i can roll it up by using the switch. Also, when I put the ignition to acc, it seems like something is activating the passenger side window to roll up, I can tell cause the window twitchs? I changed both driver and passenger side switch panels. Window motor is still workin cause it works with direct power to it. checked all fuses and theyre all ok.
What can it be? summer time is here and i need that window to roll down! So if there is anybody out there that can help that would be great!
Re: HELP!!! Passenger side window acting up!?!?! (gld96ek)
in my eg.. the relay is in the door.. you take off the panel.. and you see afew wires go into a box.. once my friends power windows didnt work and he swaped that out and it worked fine.. i hope this helps a lil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gld96ek »</TD></TR><TR><TD CLASS="quote">On my 96 civic coupe, the passenger side window not working properly. The window wont roll down but if i hook up direct power to it form the battery it will roll down and i can roll it up by using the switch. Also, when I put the ignition to acc, it seems like something is activating the passenger side window to roll up, I can tell cause the window twitchs? I changed both driver and passenger side switch panels. Window motor is still workin cause it works with direct power to it. checked all fuses and theyre all ok.
What can it be? summer time is here and i need that window to roll down! So if there is anybody out there that can help that would be great!</TD></TR></TABLE>
which wire did you tap into to get direct power from another source? I need to try this myself...
92-CivicLX
09-23-2013 07:46 AM
einzelherz
12-16-2011 02:58 PM
