help with my new car
i finally picked up my car i got a 1994 civic cx hatch it has 62,000 ORIGINAL miles on it . Everything is fine on the car execpt for my turn signals and horn. I checked under the hood for the fuse box and replaced the 10a and 20a but it still doesn't work. When i go to put on the signal it doesn't show anything not even on the cluster and for my horn it just makes a click sound. what could be wrong any help is appriciated
Re: help with my new car (redhondacivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redhondacivic »</TD></TR><TR><TD CLASS="quote">The fuse box that you need is near your left leg under the dash. Thats where these fuses should be. </TD></TR></TABLE>
yeah but which one is the one for the turn signals and horn?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dthug »</TD></TR><TR><TD CLASS="quote">more then 50 views and still no help?? common ppl need help asap!!!</TD></TR></TABLE>
people also come here to find information and expand their knowledge, not just to give information
Re: (blkSi)
The hazzard button on the dash is a red triangle to right of thre steering wheel. This control the blinkers as previously mentioned. I beleive it pops out just be gentle and firm. The horn it self may be bad. If you are close to a local pick and pull (aka junk yard) you can find used replacements for like $5.00 for both.
The hazzard switch it self is most likely the problem.
As for the horn it ssounds like the horn has gone bad, you can check to see if its getting voltage with a volt meter when the button is depressed. The horn is under the front bumper on the left side un plug the clip and test.
If you know someone with 92-95 civic you can test by swapping temporarily, both of these items are easy to access, remove and unplug, and replace.
HatchiHatch
05-27-2004 09:37 AM
