Help Me w/ My Leaking Problem...
My 93 CX has a leak on passenger side...
When ever it rains I get water on my floor.
Where do you think it is coming from?
Do I have to pull my dash out to fix it?
I want to put carpet back in but I want to fix this first.
Please help. Thanks mAT
Re: Help Me w/ My Leaking Problem... (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">What is it leaking? Gas? Oil? Coolant? Coca cola?</TD></TR></TABLE>
Edited Thanks
WATER(rain water)
Edited Thanks
WATER(rain water)
Risky Business
Re: Help Me w/ My Leaking Problem... (vtecmonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecmonster »</TD></TR><TR><TD CLASS="quote">
Fixed Thanks.</TD></TR></TABLE>
Additional Info:
Trouble Spots
Water leak: There may be water leaking into the passenger footwell because of insufficient sealer on the seam at the firewall. Look for rust on the floor pan and run water over the right lower corner of the windshield to watch for water leaks before buying the car. (1992-95)
http://auto.consumerguide.com/.../2049
Additional Info:
Trouble Spots
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote"> insufficient sealer on the seam at the firewall </TD></TR></TABLE>
How do I fix that? Where is that? Is that just under the cowl panel. I am not to sure where that is on the firewall.
1 Post
basically,look all around in the passenger side of the car for any obvious signs of leakage.maybe have a friend spray a water hose around the cowl area and try to see where it's coming thru.
this pic will help you see where all the seams come together.
chris
chris
1 Post
chris
chris
Re: Help Me w/ My Leaking Problem... (TeamNextGenChris)
I read this in a search but where is that..."Most of the EG have this problem cause honda never put enought sealant on the bulk head in the corner of your hood and dash area... "
2SlowDC
10-01-2005 08:32 PM
