Got a water leak
Got a water leak
Not a typical water/coolant leak. In about a day of rain i get a 2 inch puddle on my drivers side by my feet. I cant figure out where its coming from. Its doin the osmosis thing through the floor. N othign is dripping from the top. I spent 1 hour in my car looking for drips while it was raining. i dunno if anyone else has had a problem like this and hunted it down but any help would be appreciated.
Btw: its in my crx
Btw: its in my crx
Re: Got a water leak (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">You mean coolant and water drip inside your car?</TD></TR></TABLE>
nope just rain, fills right up...ive had to vaccum the water our numerous times lately cause its been raining alot...
And yes i do have a sunroof.
Re: Got a water leak (screamincivik)
I have the same problem man, except it's behind my driver seat. A little leaking in my hatch too...which I'm guessing is the tail light gaskets. CRX also here. I dont mind the water too much, it's the nasty stentch and condensation on the inside of my windows that I hate. I have to carry a rag to wipe down all the water from the windows so I can see
Re: Got a water leak (sporkcrx)
yeah it does tend to cause the windows to fog up more since the extra moisture in the car. Which is very annoying by itself. But basically the whole drivers side is water for me. The back doenst really get anything in it.
drain tubes, friend's GSR tubes are pluged and same symtoms, we've been haveing some crazy *** wether hear in MI latly, but it is michigan tho
Re: Got a water leak (Sideout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout »</TD></TR><TR><TD CLASS="quote">drain tubes, friend's GSR tubes are pluged and same symtoms, we've been haveing some crazy *** wether hear in MI latly, but it is michigan tho </TD></TR></TABLE>
yeah atleast its not snow....yet! godamn michigan
Re: Got a water leak (kyler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyler »</TD></TR><TR><TD CLASS="quote">If you have an amplifier, check that the water isn't running along the wire through the firewall.</TD></TR></TABLE>
thanks...no amp here, But i will be checking the fire wall for leaks thanks
Well put some work into the leak problem today. I sealed my tail light gaskets...since new ones from honda are $20 each! I also tore apart my interior and found my clogged *** sunroof drains. Cleared it up so now it should flow like hell! I pulled the end of this off and a ton of water came spraying out like a frieken garden hose. Here's the end where it was clogged...it was like this on both of them (is there front drains for the sunroof too?)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">Well put some work into the leak problem today. I sealed my tail light gaskets...since new ones from honda are $20 each! I also tore apart my interior and found my clogged *** sunroof drains. Cleared it up so now it should flow like hell! I pulled the end of this off and a ton of water came spraying out like a frieken garden hose. Here's the end where it was clogged...it was like this on both of them (is there front drains for the sunroof too?)
EWWW, where did u pull that from again?
im havin the same problem in my rex........ only its in the passenger side floor and collects about 2inches behind my passenger side seat........ im gonna check my firewall holes since i have had (2) 4gauge power wires run through there at one time....... lol
Re: Got a water leak (90civichbsi)
I've got a water leak that form a puddle behind the passanger seat on my 91 crx si/......
any ideas???
please help..... I hate to have to put the car cover on everytime it rains.....
any ideas???
I basically took out all of the rear interior, found the drain lines, took out the end plugs, got the **** out, and slapped it back in. I think there's 2 front lines too...but I have no idea of how to get to those.
Re: Got a water leak (sloorex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloorex »</TD></TR><TR><TD CLASS="quote">
im havin the same problem in my rex........ only its in the passenger side floor and collects about 2inches behind my passenger side seatl</TD></TR></TABLE>
same here, went out to get into my hatch after itd been raining all night. looked over at the pass floor and there was water above the carpet. a good 3" or so
Location: 9/11/01 WTC Never Forget, United States Of America
Re: Got a water leak (baggelis)
Check for any holes under ur car if any fill them up with silicone
also get ruberized coating is a tall can black spray good for covering up holes
Re: Got a water leak (1CiViC1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1CiViC1 »</TD></TR><TR><TD CLASS="quote">
same here, went out to get into my hatch after itd been raining all night. looked over at the pass floor and there was water above the carpet. a good 3" or so </TD></TR></TABLE>
check the weather strip on the door i get water through the door and comes out the speaker grill im gonna get new weather strips
No I don't, I have a helms too and I couldn't find much on where they really go. The only way to really get to them is take out the rear interior. It's really not that bad though, I did it all in under 1.5-2 hours...and taking my sweet ol' time.
Re: Got a water leak (Red_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_Si »</TD></TR><TR><TD CLASS="quote">mine used to do it but it stopped and doesn't do it anymore. lol guess my mad tight sit on my *** skills worked.</TD></TR></TABLE>
LOL
LOL
nonvtec92
11
04-30-2008 02:45 PM
invisible
17
05-30-2007 09:31 PM
PatrickGSR94
01-30-2005 02:38 PM
