Pansonic head unit removal
Old Aug 26, 2009 | 10:48 AM
chb93's Avatar
Default Pansonic head unit removal
Recently a friend of mine decided to upgrade his sound system and gave his old stuff to me. I had a system in my last car and had it installed by a friend of mine who is currently away at school. Ive been talking to him and he has walked me through the whole wiring process to the amp and the speaker and how to run the wires through the car, but when it came time to remove my head unit I ran into trouble. I have never removed a head unit before and dont know where to start. The head unit is a Panasonic dp940. All I have to plug in is the wire from the amp to the head unit with the plugs (the input I believe) and a small blue wire my friend refered to as the REM. He was also not sure on where that wire should go without seeing it in person. Any help would be greatly appriciated with the removal of the head unit or the REM wire. This stupd head unit and 2 wires are holding me back from getting my system up and running and I dont want to have to pay best buy 100 bucks to figure it out for me. Thanks in advance.
Old Aug 26, 2009 | 12:09 PM
XstreamRocker's Avatar
Default Re: Pansonic head unit removal
If I knew what kind of car you were driving, I could help you. We can't help you without knowing everything you do. The actual HU removal process is different with every car as it requires the removal of a few dashboard parts. With knowing the make, model, and year of your car, we can't help you.
Old Aug 26, 2009 | 01:36 PM
chb93's Avatar
Sorry its a 93 civic hatchback
Old Aug 26, 2009 | 04:13 PM
Ok. It appears that your car uses a mounting sleeve to hold the aftermarket HU. To remove the HU, you will need the removal straps that came with it. If you don't have them, it's quite possible that your friend at school has them. Either way that's how it's done. The exact process that was used to install it is a little complicated to explain but I can give you a link here:
http://www.installdr.com/InstallDocs...PDF/466017.pdf
This is a PDF that you should be able to print and will show you what I'm talking about.
Old Aug 27, 2009 | 09:21 AM
chb93's Avatar
The car had the head unit in it when I bought it so I dont ahve the straps. im going to give my friend a call and see if he has them. Thanks for the help
Old Aug 31, 2009 | 02:28 PM
D23_Si's Avatar
very helpful website....www.installdr.com...thanks!
alphalanos
Honda S2000
Mar 1, 2013 01:46 PM
Black Diamond
Audio / Security / Video
Nov 6, 2009 06:12 AM
Crossbreeder
Sep 30, 2009 09:55 AM
funtak
May 15, 2007 10:13 AM
CrazyModGSR
Aug 25, 2004 06:10 PM
