Help with me D16z6 tranny.....
tonight i went to the track and i ran 9.82 on a d16z6 with i/h/e, i was told that was good, but when i switch from 1st to 2nd i heard a grate or light grinding noise. its only from 1-2nd no other gears. what the hell could that be?????????
Risky Business
Re: (civicrights)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrights »</TD></TR><TR><TD CLASS="quote">Dont worry bout it your diff will blow in a while anyway.</TD></TR></TABLE>
huh?
huh?
D Tranny Guru
Re: Help with me D16z6 tranny..... (hj)
as THE tranny guru, check your motor mounts, but most likely you have a worn 1-2 shifter fork.
I'm up to about 50 SOHC trannys and only have ever seen one destroyed synchro.
it was the result of a broken 1-2 shifter fork.........
go buy some GM Synchromesh friction modified from your local Chevy dealership!! Let me know if it works the same wonders it works on B-series trannies!!!!???
-Bryan-
-Bryan-
D Tranny Guru
new fork is $55-60 from dealer, requires complete tranny teardown. Yours will be fine for a while as it is just worn. But when it does break you'll be shifting 1-3-4, no second gear.
JWHATCH23
04-17-2006 01:07 AM
